Old 12-22-2005, 04:59 PM
kmlayton kmlayton is offline
whobbling and alignment??
I have a 2001 Ford Taurus and I have a some whobbling going on in my car. I especially notice it on smooth surfaces and when going slow I have feel myself gently bobbing up and down in my seat that is in sync with the whobbling sound. Is this due to alignment or something else?
Also, does anyone have any info on check engine light code PO 460 Fuel Level Sensor Circuit A Malfunction? I am wanting to fix this on my own, but I am not sure if this is even a possibility. Any thoughts?
Old 12-22-2005, 05:18 PM
Crasen Crasen is offline
Re: whobbling and alignment??
You might want to check your lugnuts, if they are loose on on or more wheel they will feel like that. It could also be an out of round tire, probably not an alignment problem though
Old 12-23-2005, 04:13 AM
reekor reekor is offline
I had that on a few cars and it always turned out to be a bad tire.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 12-23-2005, 10:52 AM
mechhound mechhound is offline
Re: Re: whobbling and alignment??
I agree, if you raise the tire off the ground and look closely while you slowly turn it you will likely find a bulge on the tread surface. Most likely, but not for certain, a front tire.
Old 12-23-2005, 03:42 PM
mwt878991 mwt878991 is offline
Knowing how many miles are on the car would help in this scenario
Take your car to a qualified shop
Could be tie rods or ball joints sounds like a bad tire though
The OEm continentals are not very good
as far as the code
disconnect your battery and make sure your gas cap is tight
Mike
