Old 12-17-2005, 09:28 PM
25thTransAm 25thTransAm is offline
whats wrong with my car
I read a stock 1994 Trans Am runs 13.7 1/4 mile. My Trans Am has a Granatelli mas airflow sensor, air intake with a k&n air filter, aluminum driveshaft and ran 14.4. I gunned the shit out of it too!!
Old 12-17-2005, 09:34 PM
Nicholas1979 Nicholas1979 is offline
Re: whats wrong with my car
I don't post much, but I watch theese boards alot, I'm no expert, but some guesses from me would be the first, which is practice... how many times did you run? in the process of gunning the shit out if it, did you spin the tires?
also about the car... auto? manual? rear end gears?
Old 12-18-2005, 12:04 AM
CreepingDeath94 CreepingDeath94 is offline
I don't think that a stock '94 T/A runs a 13.7 unless possibly with a professional driver and a 6 speed. My '94 ran a 14.4 with a shift kit auto. and decent tires...and my reaction time is pretty good...
Old 12-18-2005, 07:14 AM
Darrensls1 Darrensls1 is offline
94 Trans Ams do not run 13.7 in the quarter mile. Yes it has happened but like creapingdeath said it would take a M6, low elevation, good weather and a great driver. In other words that is the absolute best scenerio. On average the LT1's run the quarter in 14.0-14.4 when in stock trim. As long as your in there and under a 2.2 60' then you are in the "normal" range.
But as your launch, shifting (if applicable) and weather improves then so will your ET. I bet with practice you can break into the 13's under good conditions. You need to hit 1.9 - 2.0 60' to get the real good ET's. Hard to do on street tires but it's definately possible on well prepped tracks. You could always put some Nitto 555R drag radials in the back and heat em up good. That'll get your 60' time down nicely
Good luck
1999 Pontiac Firebird Formula 100% bone stock. No really it is
Old 12-18-2005, 09:41 AM
1FASTws6 1FASTws6 is offline
Re: Re: whats wrong with my car
13.7 in a 94???? wow. My 98 M6 is said to run somewhere in the 13.3 13.2 ballpark with great drivers.
Old 12-19-2005, 06:30 AM
Re: Re: Re: whats wrong with my car
94 = LT1 motor
98 = LS1 motor
You can't compare the two. LT1's usually run low 14's and LS1's usually run mid 13's. Those are "normal" times. Great drivers, tracks and weather can get LT1's into the 13's stock. Likewise, LS1's have hit high 12's under premium conditions.
Old 12-19-2005, 08:00 AM
FormulaForce FormulaForce is offline
There's a ton of factors that can affect a car's 1/4 time. Tires, type of transmission, weather, track surface, rear axle ratios, weight (driver, fuel, junk in the trunk), and of course the driver's skills. According to Hot Rod Magazine, a typical car with an automatic transmission will lose about 18% of it's horsepower in the driveline. Manuals only lose about 9%. When manufacturers list performance specs for their cars, you can bet they're tested under optimum conditions: cool weather, lightweight driver, test track, about 1/2 a gallon of fuel, etc. Now put that same car in heavy traffic, during a hot summer, with a full tank of gas, spare tire, jack, and other stuff. Add your average driver, and your performance won't be anywhere near what is claimed for that type of car.
Old 12-19-2005, 05:22 PM
true.... but the car is capable of hitting those numbers. Fact is exactly like u said u cant do to all those factors.
Old 12-19-2005, 05:29 PM
I don't know about thier idea of a typical car but those numbers are a bit off for LS1 F-bodies. T56 manuals lose around 15% and the 4L60E auto is known for about a 20% drivetrain loss. But I know some M6 guys who wish they only lost 9% of thier FWHP to the wheels
Old 12-20-2005, 10:31 PM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
This might sound off the wall, but why fiddle with the MAF? Take it off, toss on the stock, get a tune, make another run.
--Jay
2002 Light Pewter Metallic Formula A4:
Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows
Old 12-21-2005, 10:42 AM
tuske427 tuske427 is offline
Send a message via AIM to tuske427
Jay is right. With the mods you have- you shouldn't need the granatelli yet. With my past 1995 T/A I had AFR heads, slp exhaust (headers and catback), gutted cat, 3:73 gears, reduced crank pulley, hypertech power programmer, fabricated cold air intake w/ K&N filter, 1le intake, ls1 driveshaft, aftermarket lca and WS-6 suspension, etc. when I installed the granateli my car felt slower off the line. I had a stock bottom end so I'd never spin my engine high enough to see the need for it.
the thing about those is they are designed for engines that require a much higher air intake such as with a supercharger or stroked engine.
You'd be better off installing the stock one back on, and concentrating on other mods first, like exhaust and gears. Your engine still needs the air velocity the stock maf provides.
You'll probably notice an increase of torque on the bottom end if you do.
Good luck!
Long live the muscle car
Old 12-21-2005, 10:43 PM
Good luck!
True, true! Not ~everyone~ (but definately the vast majority) experience problems with idle, spark advance, torque, etc. with aftermarket MAF's on virtually stock (ie - stock internals) setups.
Headers, exhaust, CAI (even an airlid) will allow a lot more air to flow through the engine than the factory stuff, all without major problems occuring (you should always get a tune after doing headers though to recalibrate the A/F mix).
If you still want a nice boost, I stongly suggest a ported TB as well as a smoother bellows (tubing from the back of the airbox/lid to the TB (and yes, the $3.99 Fernco from Home Depot works just as well, if not better, than the $50.00+ versions from SLP, TSP, etc.)
I love the sound of the LT1's when they're done up right. Just make it so it has plenty of bite to go along with it's bark. No disrespect, but get that MAF off and build from the ground up, lay all the basework and let the car adapt before before going for the bigger stuff.
((And it should be common knowledge, but NEVER de-screen the stock MAF either - you'll get the same sluggishness as with the aftermarket.))
--Jay
Old 12-22-2005, 09:49 AM
You guys may be right about the MAF. My Granatelli just failed, and I put the stock one back on. The car feels pretty fast with the stock. I had gone ahead and ordered a new Granatelli MAF, one of the new ones that's programmed for a cold-air pickup, unlike the old one. Once it gets here, I'll try to compare the two with some G-tech metered runs.
Should know within 10 days which is better. Mine is an LT-1, don't know what an LS-1 MAF is like. I also got my carbon driveshaft and will let you know how that does as well.
Here's my miami f-body jingle:
"I like drivin' like Miami Vice,
No slippin' and slidin' cuz there ain't no ice,
Up I-95 and back down the 'Pike,
All winter long I'll be cookin' Rice!"
Ps: Randell, stay out of our forum, it's not for losers like you.
