Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 12-22-2005, 01:23 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
variable valve timing
Has any bike got some variable valve timing like vvt, vtec, mivec, etc?
If not, is it at all possible to get a honda head to fit on a bike, or is it at all possible to modify a bike head to fit a car I4 vtec system?
Old 12-22-2005, 03:18 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: variable valve timing
the honda VFR 800 has vtec.
http://www.bikez.com/motorcycles/hon..._vtec_2003.php
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 12-23-2005, 08:08 AM
Ghetto-z Ghetto-z is offline
Send a message via AIM to Ghetto-z
... a honda head on a bike... or the entire intake system from a car with variable valve timing... have you ever looked at an engine?!
1989 blazer= my shiit bucket
1999 cbr600f4 with flowed and jetted carbs, decked, ported and polished head,full vance and hines exaust, scotts steering damper, custom blurple paint= my baby
Old 12-23-2005, 08:56 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Just loosen up your cam chain tensioner, and you'll have variable valve timing...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-23-2005, 10:43 AM
well, just the head, for the vtec or whatever, but the intake would probably have to be custom. i was wondering if they were at all similar in size and bolt holes, i'm guessing not.
Old 12-23-2005, 08:18 PM
It would be easier to just build a bike around a Vtec car motor (ala BossHoss w/chevy motors) than it would be to try to "reverse engineer" a bike engine to include that system.
Not just that the castings are totally incompatable, but a pretty high level of computer control specific to the design of the motor is required also...
...empty gun rack.
Old 12-23-2005, 08:22 PM
oh ok, i was just wondering. don't you think it would be smart for companies to incorporate their vairable valve timing systems in their bikes? wouldn't it provide more power and a broader torque curve? does anyone know if there are any plans of companies incorporating it in their sportsbikes?
Also are those systems restricted in motorbike races? if so, that might explain the unwillingness to put it in.
Old 12-24-2005, 01:19 AM
I'm sure it will become common on bikes, engine management computer systems for bike motors might need to catch up in sophistication first.
I don't see why it wouldn't be allowed in competition, but I don't know much about those rules.
Besides the performance boost when it kicks in, a system like that is preferable in a car because it allows it to have emissions compliance across a broad range of conditions and engine speeds, where a performance cam that works well at higher RPM produces a dirty, fuel-sucking and unstable idle at the idle speeds we expect from cars, especially with an automatic transmission.
Bike motors by comparison can idle higher, don't have to adhere to emissions standards so closely, quickly spool through the lower RPM range to get up into the powerband of the cam, can be kept in that powerband with closer ratio gears, fuel economy off powerband isn't a real big concern, etc...less real gain to be had for the complexity involved.
...empty gun rack.
