Old 12-22-2005, 11:53 AM
Pen35 Pen35 is offline
Lost Keys
I have a 1991 Cavalier, I was wondering if there is a way to start it without having the keys..? I somehow managed to lose them, and know someone who will drill the ignition out, if I can get the car to them. If there was a way to slip it into neutral or driver it would be alright, cause then I could tow it. ((Automatic Transmission.))
Thanks
Old 12-22-2005, 12:05 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Lost Keys
Call a tow truck.
It would be easier to break into fort knox then try to start it.
Even if you got it in neutral the wheel is locked and you will have no brakes or ps. And run the risk of towing it and tearing up things.
That is what tow trucks are made for.
And why people take out comp and towing on there insurance.
MT
MT
Old 12-22-2005, 12:13 PM
I didn't think there was a way, but it's worth a shot. Seemed like the right place to ask me question anyways. Thanks.
Old 12-22-2005, 01:09 PM
MT-2500's Avatar
AF - Advisor
Re: Lost Keys
10-4 on that.
You might call your dealer and see if they can make a key from the vin no if key cylinder has not been replaced.
Also look in owners manual and glove box for the key knock out pellets or a key pellet no.
A new key can be made from that no.
Or sometimes the origional owner will have a ket for it.
And also some people put a hide out key in in different places on car.
Or one other angle is to get a used steering column from bone yard.
Good Luck
MT
MT
Old 12-22-2005, 01:16 PM
MT-2500's Avatar
AF - Advisor
Re: Lost Keys
Also if the door lock uses the same key a locksmith can make a key for it if you remove the door lock and take it to him or may have the key no stamped on it.
More ways than one to shin a cat.
Goodd Luck MT
MT
Old 12-22-2005, 01:40 PM
We took the VIN number to a Chec dealership and got a set of keys cut, door and ignition. Apparently the ignition on the car must have been changed at some point because the ignition key didn't work, though the door one was fine.
Were thinking of removing the ignition and taking it into a locksmith, seems that it would be cheaper then having to haul it the whole way to the city.. which is a long way when you live in the country.
Is removing an ignition a tricky job? I got some vague instructions about taking off the steering wheel and moving the signal lite switch.. might get it, with some tinkering.
Old 12-22-2005, 02:02 PM
MT-2500's Avatar
AF - Advisor
Re: Lost Keys
To remove the key cylinder you need the key to turn in to the right position.
About the only without the key is to drill inside out of cylinder.
And remove steering wheel and turn signal and get locking pin out plus the crazy buzzer switch.
A good service manual will help you.
If it has a air bag do not try it yourself outside of the drilling out part. which is not covered .
Good luck
MT
MT
Old 12-22-2005, 02:08 PM
MT-2500's Avatar
AF - Advisor
Re: Lost Keys
Or if you have access to or can rent/borrow a car toter the trans linkage can be unhooked to push car on it.
Good luck
MT
MT
Old 12-25-2005, 07:53 AM
cousincletus cousincletus is offline
I would just call a locksmith if you can't get a new key made from the VIN. May cost 100 bucks but less aggravation and potentially less money than monkeying with your steering column.
Old 12-25-2005, 09:11 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: Re: Lost Keys
Good luck
MT
95+ = Airbag
94 and down = No Airbag
His = 91.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 12-25-2005, 09:49 AM
MT-2500's Avatar
AF - Advisor
Re: Lost Keys
10-4 on that Steve
I always put that in there to be on the safe side.
MT
MT
Old 12-25-2005, 12:42 PM
89Sunbird 89Sunbird is offline
Re: Lost Keys
You can buy lock cylinders and keys at Autozone...have the option of black or chrome keys, even :P
