Old 12-22-2005, 10:28 AM
arunspolia arunspolia is offline
TRANSMISSION iSSUE
I have a Honda civic 1988 model anf got stuck up in snow. I was rtying to take it out and dhifting geras back and forth . I had to call a tow truck later. Now only mu reverse gear is not working, I can shift the gear lever to R, however the care dors not move, all other gears are working normally
What shouls I be aware if before going to a workshop, so that I do not get rippped.
Thanks
Old 12-22-2005, 10:51 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Re: TRANSMISSION iSSUE
moving to Civic forum.
Old 12-22-2005, 10:57 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
If the price of parts is going to me more than 150, I'd look for another tranny b/c you can pick them up for 150-200 bucks.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 12-22-2005, 12:26 PM
Re: Re: TRANSMISSION iSSUE
does this have to do with a loose cable, or something as only the Reverse gear is not working, I can out it to R position effortleesly, it however only does not engage
Thanks
Old 12-22-2005, 01:26 PM
its not cable operated, its done by linkage. It could possibly be bent or loose.
However its odd that it can move into position and not engage. Did you hear any loud and/or strange noises while you was doing it?
You could have broken a gear, or shaft inside.
Old 12-22-2005, 01:42 PM
[quote=jeef]its not cable operated, its done by linkage. It could possibly be bent or loose.
You could have broken a gear, or shaft inside.[/QUOTE
No did not hearany noises, the wheels were spimnning and egine reving up , so I might not have noticed.
so the only option is to open up the transmission now, right
Old 12-22-2005, 03:27 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
have you check your atf fluid level yet?
Team Lonely Drivers
Old 12-23-2005, 06:19 AM
Yes the fluid level was fine. now Reverse is working flawlessly. now 4th gear works till 45 KM per hours and then gives a grinding noise, The car runs ok on 2nd and #rd gear. The car is automatic.
Old 12-23-2005, 07:22 PM
oh shit, didn't even realize it was an AT, those are out of my realm, never tore one a part so i'm not sure quite how they work.
But I do remember reading in the honda manual that they reccommend not rocking the auto.
Old 12-24-2005, 12:22 AM
does it grind in 3rd gear at 45kmph?
Team Lonely Drivers
Old 12-24-2005, 12:28 AM
allstar323 allstar323 is offline
if you read the civic manual that came with the car, it says not to do what you did...shift gears back and forth and spin the wheels, as transmission damage may occur. Sorry.
Old 12-25-2005, 11:01 PM
Floyd_ODB Floyd_ODB is offline
Yep!! prbly burnned a seal and or the clutchpack or band
Old 12-28-2005, 06:42 AM
Reverse works on and off
4th gear grinds 45 Km/hour and above
runs grest on 3rd gear
what is the remedy besides getting new transmission about $400 + labour
thanks
