Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-22-2005, 09:41 AM
Huntley26 Huntley26 is offline
88' 4runner problem
Here are the symptoms, I turn the key to on and the rear window will not roll down, the rear wiper will also not work. When I try to start it nothing, no click from the solenoid or anything. I rebuilt the solenoid and replaced the battery ground cable with no luck. I have turned the key to start and the headlights do not dim or go out. I have turned the key to start with the clutch cancel switch on, nothing. Any ideas?
Old 12-23-2005, 01:02 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
Re: 88' 4runner problem
Famous starter contacts?! You might have two issues here. The no start one and then the rear window issue. Check fuses for the rear window/wiper. Is the wiper arm against the glass/body? Just some ideas.
WAR UTAH!!
Old 12-29-2005, 10:08 AM
I have made sure the rear wiper is in the correct place, checked all the fuses and cleaned and reattached the starter contacts. Still nothing, I am stumped.
Old 12-31-2005, 02:25 AM
Northern Sun's Avatar
Northern Sun Northern Sun is offline
Send a message via AIM to Northern Sun Send a message via Yahoo to Northern Sun
tailgate harness, 15 cables altogether, bet u few of them are shot 4runner harness is a joke(no offense to anybody) hope it helps, Northern Sun
Vietcong 3VZ-E
Old 12-31-2005, 09:36 AM
I will check it out. Thanks all.
