Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 12-22-2005, 07:44 AM
crashedu182 crashedu182 is offline
Send a message via Yahoo to crashedu182
rear end question
kinda new to this but is there a pin in the rear gears that makes it poss trac got a broncol but it seems to have limited slip, i was told these pins break causing that
Old 01-13-2006, 11:04 PM
gbic1 gbic1 is offline
No they use clutches
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 01-18-2006, 06:03 PM
BRONCFOOT BRONCFOOT is offline
Re: rear end question
The pin is in both single and limited slip axles.It holds the spider gears in. What breaks is the hardened bolt that holds the pin in. You usually have to center drill it and use a EZ out if the bolt head snaps off. Be careful when you first start to turn it with a wrench,if it breaks it is a BIAAATCH!
Old 02-07-2006, 06:27 PM
will the truck still move if it breaks? it acts like it has lim slip ,,,,,it moves fine now ,, but its just a toy and i want it to get through mud good as it can,,, just hoping to find out what i can do
