Old 12-22-2005, 07:46 AM
kevin2569 kevin2569 is offline
Check guages just now turned on. HElP
A red light appears on my car when I first start to run it. I start the engine, take off and as soon as i make a turn (Usually left) the red light turns on for a few seconds then goes off. After the first time it goes on, it no longer comes up unless i have my car off for a while and start it up again. The red light is a square with a red arrow in it pointing down. There are also squiggly lines in the box. I do not have a manual to check this. It only started recently. It does seem to stay on longer the more time goes by. Any ideas? Should i freak out hear? I really need my car for work.
Old 12-22-2005, 08:34 AM
cdru's Avatar
cdru cdru is offline
Re: Check guages just now turned on. HElP
Add coolant.
Vinyl adds horsepower, right?
Old 12-22-2005, 09:39 AM
Re: Re: Check guages just now turned on. HElP
Originally Posted by cdru
Add coolant.
I checked the coolant researve and it is full. I think it might be the gas since I am on E.. I will fill it and see it that shuts it off.
Old 12-22-2005, 12:17 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
It could be gas is why check gauges is coming on, but that signal is the coolant. If your coolant is full and its still on its a bad sensor.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
