Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-22-2005, 02:19 AM
1987ss's Avatar
1987ss 1987ss is offline
rear defrost?
when i turn on rear defrost in 92 se and leave it on for 5+ minn.. it makes it so power locks and power seats dont work as well as defrost for about 15 min, then it all works just fine? any ideas??
Old 12-22-2005, 02:58 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: rear defrost?
There is a circuit breaker which controls those accesories. The breaker could be getting old, causing it to trip early. It will be a 30 amp, mounted in the fuse box. It will look similar to a fuse, but it will have a metal cap on top of it..
Old 12-22-2005, 02:36 PM
1987ss's Avatar
Re: rear defrost?
thank you im a go check it out right now ill post back
Old 12-23-2005, 01:13 AM
1987ss's Avatar
Re: rear defrost?
i took one from a dash i have, and it popped quicker than 1 in there.. they also get extremely hot.. why what next? check grounds? were would they be any i deas? thanx
Old 12-27-2005, 06:03 PM
Re: rear defrost?
You may want to inspect/replace the defrost switch. I've had cases where the switch overheated and nearly caught fire.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 12-28-2005, 06:26 PM
1987ss's Avatar
Re: rear defrost?
thank you ill check it out
Old 12-29-2005, 04:52 PM
auto trainy auto trainy is offline
Re: rear defrost?
It sounds like your drawing a lot of amperage,have it checked soon.
