Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-21-2005, 11:59 PM
Asclepeus Asclepeus is offline
Heater Fan quit
I have a 97 jimmy sl Heater fan was working fine I stopped shut off truck went into a bookstore for a 1/2 hour came back out started truck, no heater fan. Any Ideas? I checked the fuses in the cab they all check out but I don't know if there is another set under the hood or not Any help would be great.
Old 12-22-2005, 12:03 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Heater Fan quit
I heard of the switch going out on those quite often. I'd check the fan itself too.
Old 12-22-2005, 12:37 AM
Re: Re: Heater Fan quit
I'm really hoping it's the switch I don't have the cash for a new fan. Also There was no indication anything was wrong with the fan it has worked fine since I got the truck in June would it just go like that??
Old 12-22-2005, 12:52 AM
Re: Heater Fan quit
Expect to pay around $13 for the switch, and about $35 for the motor.
Old 12-22-2005, 07:51 AM
Re: Heater Fan quit
Does the fan switch just pop out of the dash or do I have to get at it from behind
Old 12-22-2005, 03:23 PM
Re: Heater Fan quit
You must remove the trim around the radio and switches. Then remove the 4 screws holding the control assembly to the dash. Then just remove the knob, wiring and there will be a plastic clip or two holding the switch in place.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 12-22-2005, 09:16 PM
jester_11 jester_11 is offline
Re: Re: Re: Heater Fan quit
hey i have a 93. i had the same problem. i tested all the leads including te one to the fan motor and it had power. when i tested the motor it worked. turned out to be a loose wire. try that first if not too late
Old 12-22-2005, 09:25 PM
Re: Heater Fan quit
Going to go looking for a loose wire fan worked fine when I started truck this morning worked all day then quit on me after I shut the truck off for 5 mins
Old 12-22-2005, 09:44 PM
good luck. i got lucky. check the connecting wire and prong on the blower motor itself. sometimes rust builds upp and by you removing it it might have cleaned it enough
