Old 12-21-2005, 10:15 PM
sljones sljones is offline
1999 Astro security light/ignition problems
My 1999 Astro has been having an intermitent problem with it not starting. This van doesn't have a pass key. I've been told by mechanics that are working on it that only the Chevy dealer has the manuals to fix this problem. My mechanic spent 1.5 hours looking through manuals at the dealer and wasn't able to find anything. He's gonna check again tomorrow. I have an after market alarm on it but the peolpe who installed it said it wouldn't have anything to do with the factory security system. Any ideas?
Old 12-24-2005, 12:25 PM
sreve sreve is offline
Re: 1999 Astro security light/ignition problems
you van has the passlock system. first is the security light flashing? post back. a scan with a tool capable of reading body codes would be a help check for passlock codes. also in data see been check to see if the fuel has disabled. as far as the alarm not causing it: after market alarms and remote starters are the cause of many problems,alot of times from the crappy installation work ie: scotch locks with no connection or the wire cut in two, butt connectors with bad crimps. also the service eng. light not being on does not mean it has no codes.
Old 12-24-2005, 01:57 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Sreve
Good info.
Would you be the same Sreve on the Bat auto show?
MT/crunch
MT
Old 12-26-2005, 07:49 AM
Re: Re: 1999 Astro security light/ignition problems
Originally Posted by MT-2500
Sreve
Good info.
MT/crunch
hello crunch, yes it is me . i hang out here somtimes and 3 or 4 other places.
Old 01-05-2006, 08:15 PM
raycorri raycorri is offline
Just thought I would point you to a really good discussion on the Malibu forum.
http://www.automotiveforums.com/vbul...d.php?t=454520
