Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 12-21-2005, 10:01 PM
funkyjunky funkyjunky is offline
94 Trans Port will not start
1994 Trans port---
I drove to work, came out 8 hours later and it won't start. The lights come on and stay on. Turn the key and there is nothing. No click no whine. When I let go and the key returns to the inital position it makes a slight whirring sound. The battery and alternator were replaced a few months back. It is stuck 60 miles from home right now so any help is appreciated!
Old 12-22-2005, 08:59 AM
LMP's Avatar
LMP LMP is offline
Re: 94 Trans Port will not start
Originally Posted by funkyjunky
Turn the key and there is nothing. No click no whine. When I let go and the key returns to the inital position it makes a slight whirring sound. !
As I read it word for word, I understand there is no "whine" at first "turn ON" of the ignition switch..that is you do not even hear the 2 sec fuel pump burst...then turn to start position ..nothing at all ..then on release of the key then you hear the fuel pump whine for 2 sec. To me it sounds like the ignition switch has gone haywire....
Correct me if I miss something. In the mean time, may be this can help.
www.avigex.ca/xport/starterdiagram.jpg
www.avigex.ca/xport/starterdiagnosis.jpg
IF in fact you get the fuel pump whine at the first turn ON, starting is inhibited if the neutral/park switch is not in right position, so may be jiggling a little with the shift stick could position it properly....just for a check, put it in reverse to see if back-up lights turn on...
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
