Old 12-21-2005, 10:01 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Tick, Tick Tick tick..........
hey guess what?? theres a ticking sound coming from my engine. woo hoo. oil pressure gauge a lil screwy. not off that bad but bouncin around a little. more than normal. could i just need to change the oil and filter again since the gasket repair(intake manifold). still runs good. i let it warm up 15-20 minutes. somedays u just cant but 99% of the time i do. or should i go synthetic all the way. color me clueless??????????!!!!!!!!
http://jowulf.deviantart.com/
Old 12-21-2005, 10:25 PM
laxman21's Avatar
laxman21 laxman21 is offline
Re: Tick, Tick Tick tick..........
I have a ticking/tapping sound at start up. Goes away after it warms up. But, hey, I have 236K. Mechanic told me what it was, a valve tappet going bad.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 12-21-2005, 11:59 PM
OverBoardProject OverBoardProject is offline
Banned
My guess that it's lifter noise GirlBear.
Since if I remember correctly you recently had the intake manifold off I would almost think that one of your valve adjustment nuts might have backed off. That is if you have to mess with the valves while doing a 4.3L intake manifold.
Old 12-22-2005, 12:07 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I'd say your oil may be diluted with antifreeze. Did you change the intake gaskets because of coolant loss?
Old 12-22-2005, 02:33 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Cool Re: Tick, Tick Tick tick..........
You changed the oil before cranking up after the intake gasket change , Right . I use synthetic in everything now , even my lawn mower. In your cold climate , my opinion is you should go synthetic . I just bought a jug a couple of hours ago for my next change . See if you can round up one of those mechanics stephascopes(?) to try to pinpoint the tick . Could be something as simple as an injector.since I removed my troublesome throttlebody F.I. , My computer clicks loud and varies with engine speed . I think it misses the injectors and sensors . I don't miss the problems . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 12-22-2005, 02:52 AM
Banned
GirlBear, I can't believe that this didn't occure to me right away.
most motors that I see with what sounds like valve tick noise ends up being a small exhaust leak. Always somewhere at the exhaust manifold, and usually the gasket or a loose bolt.
Old 12-22-2005, 08:09 AM
cleanshavenrsx cleanshavenrsx is offline
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
do they engine gunk flush and convert to full sythetic... see if it works wouldnt hurt... i get higher oil pressure with synth. maybecause its thinner and more slippery
Old 12-22-2005, 10:11 AM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: Tick, Tick Tick tick..........
GirlBear, If OverBoards hunch is wrong. And it is in fact coming from your motor. Try this. Using a large screwdriver. Hold it up to your ear and touch around the valve cover while the motor is idling. See if the noise is in fact coming from your lifter. If so, when you did the lower intake gasket replacement. There is that possibility that some small pieces of debris were left inside, and made its way to one of the oil galleys or just got stuck in one of the lifters. You can try using a can of engine flush and run the motor for about 20 or 30 miles on the freeway, then do a complete oil change with filter. Synthetic oil would be preferred. I've had that happen once, and it worked for me. Good Luck and let us know how your doing, and what you find.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 12-22-2005, 10:28 AM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Every car that i've ever owned that has fuel injection has a tick tick to it. I'm told thats the injectors working, hondas and acuras really tick. I never listened to my blazer though to see if that does it, i just thought i'd throw that out there. Good luck
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 12-22-2005, 12:54 PM
BlazayBlazerious's Avatar
BlazayBlazerious BlazayBlazerious is offline
Sounds like it could be a stuck lifter. Especially since its been getting really cold out. From inside the truck, does it sound kinda like someone tapping a pencil under the hood somewhere and it goes away after your engine warms up?
1998 Blazer LT 4X4
So stock it's got the
original oil in it...
well, not exactly
Old 12-22-2005, 05:04 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: Re: Re: Tick, Tick Tick tick..........
Make sure your hair is up if you're gunna try the screwdriver method!
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 12-22-2005, 05:13 PM
Banned
Re: Re: Re: Re: Tick, Tick Tick tick..........
It's a good idea with any car repair.
Also don't wear loose clothing and take all jewelery off including rings
Old 12-22-2005, 06:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Girlbear, what oil filter do you use?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-22-2005, 06:14 PM
GirlBear's Avatar
after i did the intake i flushed the coolant and drained/changed the oil/filter. When i start it it always ticks a lil. but as it warmed up the ticking would stop. last night after drivin all day and night(xmas shopping) on the way home i noticed the ticking. im gonna flush it. im thinkin cause the galley was soooooo shitty sumthin must have fell in there. thanx guys im gonna go the synthetic route. ill keep ya's up to date.
Old 12-22-2005, 06:20 PM
GirlBear's Avatar
advance auto's brand i think maybe ac/delco. not sure tho. 2maro im gonna lift'er up and check it out. shes been sittin all day.
