Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-21-2005, 08:48 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Thumbs down Another Problem!! -> Cruise Control
Alright guys... I've got yet another problem. My cruise control stopped working on me. Last time it stopped working it was just a vaccume line that came undone, but now i cant seem to fint anything wrong. I've checked ALL vaccume hoses. Any ideas? Thanks!!
P.S.: 1984 Caprice Classic/4BBL 305/700R4 Tranny
Old 12-21-2005, 09:09 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Another Problem!! -> Cruise Control
Well, there's that big diaphragm that attaches to the carb via linkage. Disconnect the vacuum line to it, then depress it in as far as you can while holding your finger over the vacuum attachment. You should feel vacuum on your finger when you let the diaphragm go. If it reinflates and you're positive it's not the seal around your finger that's letting it do so, then you will need to replace the diaphragm. Also, check the control head under the hood on the driver's inner fender - make sure the electrical connections are all tight and that no speedometer cables have fallen off or broken internally due to a jammed control head (both cases speedo won't work and you'll get a service engine soon light with a code 34 due to VSS). The only other area would be the switch on the steering column.
Old 12-22-2005, 04:53 PM
PeteA216's Avatar
I hope its the diaphram, I happen ta have a spare. I'll go do some investigating and I'll keep yah posted. Thanks!!
Old 12-22-2005, 05:30 PM
ruberpoliceman ruberpoliceman is offline
Wow. Glad im not the only one with problems. my cruz control is gone bum 2. I havent realy looked into it yet but i know im definately getting code 34 (VSS) and as far as i can tell the speedo is working fine but anyways i guess ill check that stuff sometime. later guys.
Old 12-23-2005, 03:26 PM
PeteA216's Avatar
It turns out it is my diapham. Its sucking air from some unknown source, so I'm gonna replace it tonight, or tomorrow. Thanks for your help!
Old 12-25-2005, 07:00 PM
thats whats wrong with mine also. I checked it the other day: put my finger over the vacuum hose connector thing and felt nothing when i pushed the diaphram in so i guess its time for another trip 2 the pick and pull.
Later.
Old 12-25-2005, 09:15 PM
silicon212's Avatar
Confoundingly Lucid
That's a common occurance with those types of CC - I used to have a perfectly good diaphragm in the parts bin but threw it out when I moved considering I don't have a car with the need for it. Oh well - at Ecology (if you're in AZ or SoCal) will sell you one for perhaps the cost of a six-pack.
