Old 12-21-2005, 08:18 PM
willysb3152 willysb3152 is offline
turn signal drl and brake light trouble
I have a 2000 Lumina 3.1 w/210,000 miles . About 6 weeks ago the daytime running lights quit coming on, bulbs are good. A week ago the left turn signal stopped working all bulbs are good and fuses check ok. Today all turn signals stopped working. I still have headlights , right brake light and taillights are on when head lights are on. Also front turnsignals and right rear flasher when emergency flasher is on. Have been told it might be the wiring harness (loom) in the steering column. I need help before I go crazy. Thanks for any ideas.
Old 12-21-2005, 08:28 PM
jd-autotech jd-autotech is offline
two things
that car is famous for multi function switch problems(turn signal switch) in the columnbut ussally u see the brake lights quit working except for the third high mounted one. second of all ussally when i ssee alot of goofy electrical problems the sorce is often a trailer wiring pigtail on the back if there is a hitch on this car
Old 12-21-2005, 09:11 PM
Re: two things
Thanks for the reply. Can't be a hitch, don't have one. Are the turn signal switches hard to replace (air bag trouble) ?
Old 12-22-2005, 02:17 AM
cadgear's Avatar
cadgear cadgear is offline
Re: turn signal drl and brake light trouble
Next thing on the common problem chart is the headlamp switch itself. Though as far as replacing the TSS, if you're careful and mindful of the airbag, there should be no problems. Though be especially careful in the winter, static electricity and electric ignitors aren't best of friends.
I'd check into the headlamp switch, though to be honest you'll probably want to do the TSS soon anyhow. Pick up a Haynes manual from the parts store to help you along, they're great for home mechanics.
Old 12-22-2005, 07:19 AM
Re: Re: turn signal drl and brake light trouble
Im going to bet on the TSS. A couple of months ago I was turning and the signal did that rapid blink sound so I bumped the switch and that made it stop. No more trouble for a few weeks then it happened again. I will replace the TSS. Thanks
Old 12-31-2005, 09:10 AM
Re: Re: Re: turn signal drl and brake light trouble
The TSS cured the problem. The worst part of the job was pulling the wires up thru the column. It would have been easier if I had cut the connector off before I staryted to pull them thru.
Old 12-31-2005, 03:31 PM
Rubicon1 Rubicon1 is offline
Re: Re: Re: Re: turn signal drl and brake light trouble
I bent the connector sideways, with the stiff wires it held in the shape and made it much easier to slide thru the top of the column.
Old 03-03-2006, 03:19 PM
JBMark33 JBMark33 is offline
Send a message via AIM to JBMark33
how much was the new TSS and or wires?
