Old 12-21-2005, 05:09 PM
cleanshavenrsx cleanshavenrsx is offline
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
::95 Blazer:: Question about factory alarm.
My 95 blazer came with no remotes and the factory alarm box is in the glove box. i wanted to know if anyone know if i can just buy a remote and get it programed and just hook back up the factory alarm..
Also can i get the newer remote like the 96 up not the old square ulgy one???
Old 12-21-2005, 05:16 PM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Re: ::95 Blazer:: Question about factory alarm.
Im pretty sure that you can get a transmitter off of ebay and the dealer will re-program it for you. I have one i'll give you for nothing, but its the old square type... not sure if you can use the new style
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 12-21-2005, 06:26 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
i don't believe u can use the newer style remotes on a 95. we have to use the square ones. u can also program it youself;
- remove the panel under the steering wheel (i believe 3 7mm screws)
- with the doors closed, use a paperclip bent into a u shape and insert it into the red connector (not connected to anything, hanging in the upper left). this runs to the keyless entry unit.
- the locks will cycle and ur in programing mode
- hold unlock on the remote while still holding the paperclip in the connector
- the locks will cycle again and ur done
do this for each remote if your buying more than 1.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 12-22-2005, 08:01 AM
wow i thought it was possible to do yourself thanks for that info... and hyper ima take you up on that your the man!
Old 12-22-2005, 09:41 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
The 95 does use the rectangle shaped units still.
The numbers on back are:
FCC ID: ABO0104T ( AB00104T )
GM #: 15955702
Canada: 218 K1035
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 12-22-2005, 09:57 PM
93LT 93LT is offline
It shouldn't be an alarm, just a keyless entry. If it says anything about an alarm on the module, it's an add on, be it dealer or aftermarket.
Rod
1995 K1500 Ext. Cab Stepside
1997 Olds Bravada AWD
2001 Silverado LT 2500HD CC 4WD
2001 Yukon SLT 4WD
Old 12-25-2005, 06:01 AM
it says gm factory alarm
