Old 12-21-2005, 04:25 PM
97_GS's Avatar
97_GS 97_GS is offline
Send a message via AIM to 97_GS Send a message via MSN to 97_GS Send a message via Yahoo to 97_GS
Angry clutch/trany problems 02' Firebird
I have a '02 Firebird with barely over 20k miles on it and its acting up...
when im parked and try to put it in reverse it doesnt want to go, I have to pump the clutch and then 9 times out of 10 it grinds horribly going into reverse, it doesnt do it in any other gear, someone suggested it might be the clutch linkage, could it be anything else?
I want to get this fixed before i have to drive from alaska to texas next month.
'04 Dodge Ram 1500
'04 Nissan Xterra
My programs never have bugs, they just develop random features.
Old 12-22-2005, 11:17 PM
Scottman72 Scottman72 is offline
Your car probably has a hydraulic clutch , check to see if the fluid is full ( should be a small resevoir next to the master cylinder ) and if that is full you can try bleeding the system. If bleeding doesnt help you may have a bad clutch cylinder or slave cylinder.
Old 12-28-2005, 01:49 AM
97_GS's Avatar
Re: clutch/trany problems 02' Firebird
Well Im gonna use my extended warranty to have the dealership look into the problem, so hopefully i will be able to get it fixed before i have to leave.
'04 Dodge Ram 1500
'04 Nissan Xterra
