Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-02-2005, 04:16 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Read First - FAQ & how to thread!!
I will be updating this forum, please give me some time to get it worked out as I only have a few minutes each day to deal with this. After I get it started I will give everyone an opportunity to reccomend changes or additions to its contents.
Regards,
John
Click links for how to sections
Body/Paint Exterior
Rust repair around windsheild
Replacing door hinge pins and bushings.
Replacing door hinge pins and bushings Illustraded
Restore your weathered plastic how-to
Engine Performance/Diagnostics
4.3 CPI Injector replacement
***92 - 95 CPI Engine Info.***
Fuel economy and General Maintenence reccomendations
List of OBD II Codes
Basic Cooling System Advice
Suspension and Drivetrain
1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!!
Ignition Electrical and Wiring System
First Gen Instrument Cluster Conversion
Ignition Switch replacement procedure
Old 12-02-2005, 06:12 PM
blazee's Avatar
blazee blazee is offline
Problem?
Faq thread suggestions.
Here's another door hinge pin and bushing how to, it's got a little more detail than the current one:
http://www.automotiveforums.com/vbul...d.php?t=476619
We see a lot of CPI problems here. Here's a thread with info about it:
http://www.automotiveforums.com/vbul...d.php?t=462726
Here's one with some great pics:
http://www.automotiveforums.com/vbul...d.php?t=473110 <--- EDIT nevermind you posted that one while I was typing.
Cluster Mod how to:
http://www.automotiveforums.com/vbul...d.php?t=379971
Drum to Disc Brake how to:
http://www.automotiveforums.com/vbul...d.php?t=372515
Heated seat how to:
http://www.automotiveforums.com/vbul...d.php?t=366533
Factory fog light switch with after market fog lights how to:
http://www.automotiveforums.com/vbul...d.php?t=356665
Info about common tranny problems:
http://www.automotiveforums.com/vbul...d.php?t=461182
Low speed ABS activation:
http://www.automotiveforums.com/vbul...d.php?t=425516
96+ Hard start, no start, rough idle info:
http://www.automotiveforums.com/vbul...d.php?t=450484
List of RPO codes:
http://www.automotiveforums.com/vbul...d.php?t=450285
A little info about fuel trims:
http://www.automotiveforums.com/vbul...d.php?t=429831
Purging air from your cooling system:
http://www.automotiveforums.com/vbul...d.php?t=469926
Water cylinder decarbonization:
http://www.automotiveforums.com/vbul...d.php?t=283211
More to come that's all I could remember right now, but I know that a lot of guys have posted some great info on here, so I'll keep looking.
Closed Thread
