Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-21-2005, 03:01 PM
BigRedAurora BigRedAurora is offline
what's the differance in the ECM and PCM
can anyone tell me the function of the ECM and PCM ??
and where they're located ?? thanks
Old 12-21-2005, 03:14 PM
maxwedge maxwedge is offline
A990 racer
Re: what's the differance in the ECM and PCM
Ecm is an old term it is now the the pcm, controls engine and trans and other intergrated functions. Most likely mounted somewhere under the hood, cannot be sure of the exact location.
Old 12-21-2005, 11:05 PM
i understand that a new PCM has to be programmed.is a dealer the only one that can program a PCM ??
Old 12-21-2005, 11:19 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
If your thinking of replacing the PCM, you may want to pick one up at a salvage yard for a ton less $ than new. Make sure the replacement came from the same year, make, model w/ the same engine, transmission, etc..
Old 12-22-2005, 07:31 AM
how are they programmed ??
Old 12-27-2005, 12:01 AM
vamc's Avatar
vamc vamc is offline
The dealer will flash the pcm, all will be restored.
