Old 12-21-2005, 01:27 PM
Ted_Mecheng Ted_Mecheng is offline
Question Rear Brakes
Hi everyone,
I've got a small technical question for you. Can anyone tell me how much cable movement at the caliper is required to engage the rear brakes when parking? I've emailed a number of companies but as of yet I have not been able to get any answers. Any help would be appreciated as it would aid in developing my university project.
Cheers
Old 12-21-2005, 01:35 PM
astroracer's Avatar
astroracer astroracer is offline
Re: Rear Brakes
Originally Posted by Ted_Mecheng
Hi everyone,
Cheers
Usually around 1/2 to 3/4's of an inch. Of course this can vary with pad wear, adjustment and if it is a disc or drum application.
Mark
Old 12-21-2005, 04:58 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Rear Brakes
Depends on the caliper.
Old 12-22-2005, 12:04 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Rear Brakes
I like the 1/2" number. Some are less or more depending on where the cable attaches to the shoes. Some use a high rate of mechanical advantage at the parking brake lever in the cabin while using a long throw in the brake itself. Others use a minimal rate of mechanical advantage in the cabin while the cable attaches further away from the pivot point of the shoe.
Best idea is to crawl under a car and mark the cable. Then set the parking brake and measure how far it goes.
Dragging people kicking and screaming into the enlightenment.
Old 12-22-2005, 12:18 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Rear Brakes
I get about 1 1/2" of travel..
