Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 12-21-2005, 01:18 PM
avi_shane avi_shane is offline
Unhappy 2002 Galant Noise?
Hey, can someone help me out, it seems that my car is making a noise . The noise ( a click) seems to be comming from my passenger front wheel, ( "I'm freeking out, man") I have an automatic is it the wheel bearing? or just need greese? or is it just me?
thanks for your time
Old 12-30-2005, 12:16 PM
1999mitjd 1999mitjd is offline
Check transmission mount i had the same problem i went thru alot to find the noise i spent $700.00 on new struts and that did not do it but then the noise got worse and found that the tras.mount was bad so i had it replaced about $180.00 and no more noise. hope this helps
Old 12-30-2005, 12:19 PM
Re: 2002 Galant Noise?
Thanks Alot
Old 12-31-2005, 12:18 PM
the_guy the_guy is offline
Re: Re: 2002 Galant Noise?
By transmission mount do you mean transmission pan cover?
Old 12-31-2005, 02:58 PM
If You Stand In Front Of Car It Is On The Right Side (driverside) On My Car It Is Under The Battery Mounted To The Transmission. Silver Color. Flat Plate On One Side And Is Round And Has A Rubber Gromit Inside. If That Is Missing Or Damaged Then You Need A New One. Try That And Get Back To Me If You Need More Help.
