Old 12-21-2005, 11:20 AM
[email protected] dlee@ssfb.com is offline
Help Clutch Rattling Noise...
I just purchased a 92 3000GT SL with only 40K very nice shape. I have found that when I leave the car out of gear and the clutch released ( not pressed down ) there is a rattle coming from the front area of the car. When I press the clutch in the rattling stops. The car runs fine and drives fine but I am curious to see if anyone else has encountered this problem. The car is completely stock no MODS at all. Have any idea?
Old 12-21-2005, 12:06 PM
2old 2old is offline
Re: Help Clutch Rattling Noise...
My guess (and this is a really big guess) but it sound like the throwout bearing is worn (which might explain why the rattle goes away when you press the clutch in)
Old 12-21-2005, 05:50 PM
Gateway's Avatar
Gateway Gateway is offline
i had the same thing happen to my car (2 times) it rattled and when i put the clutch in it went away. shortly after that started happening my clutch went out.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 12-22-2005, 12:56 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
throwout bearing
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-22-2005, 07:37 AM
I done some testing last night and once the car warms up it does not rattle. I even took it to a transmission place and they could not detect the rattle or find anything wrong doing a test drive. Thanks for your help so far. I was wondering if this particular situation has happened to any of you.
Old 12-22-2005, 07:53 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
I'm definitely with the rest of the guys, throwout bearing...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 12-22-2005, 11:47 AM
Linebckr49's Avatar
i drove a shop truck for a while when i worked at a mechanic shop. there was the same rattle in the transmission when the clutch was engaged and in gear. but when the clutch is disengaged (clutch pedal pressed), no rattle. Boss (master mechanic)said it was the throwout bearing...he said that's the only thing it COULD be. but it didn't affect the car's performance at all. actually, i still think it rattles 3 years later. drives fine.
but if i were you, i would want to fix the rattle, since its your daily driver (and a shweet 3/S), which is no shop truck for hauling crap around.
93 3000GT base
Old 12-22-2005, 07:54 PM
AutostradaVR4 AutostradaVR4 is offline
same thing is going on with my car. anyone know how easy of a fix the bearing is and how much it will run us?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 12-22-2005, 08:55 PM
Pizzaguy Pizzaguy is offline
yeah, i had the same problems...basically....you're spending money for the work...the throwout bearing is 28.88 from discount auto..and 6 hours of work...pulling the tranny out sucks..
Old 12-23-2005, 12:35 AM
Linebckr49's Avatar
pizza dude is correct. its an easy swap and a cheap part. only hard part is dropping the tranny and putting the tranny back in...ALL LABOR.
93 3000GT base
Old 12-23-2005, 07:14 AM
Mikelb's Avatar
yeah, as both of them said... LABOR... the part is only $30 roughly... but correct me if I'm wrong guys, but won't u need more transmission fluid?... b/c I spilled alot when dropping my tranny... so I'd suggest getting some beforehand, so you don't run the tranny dry, or have to stop mid project to go pick some up...
Old 12-23-2005, 01:58 PM
Linebckr49's Avatar
yes, you'll need more tranny fluid b/c when you drop the tranny, you have to remove both half-shafts (drive axles), and doing this will drain the tranny partially. if you want to change to a different tranny fluid, this would be a good time to do so. but remember to drain ALL the fluid out via the drain plug, then fill back up.
93 3000GT base
Old 12-23-2005, 01:59 PM
Mikelb's Avatar
yeah... it's not really a good idea to mix fluids, especially not if one had been used/burnt... that'll screw everything up...
Old 12-23-2005, 04:56 PM
sounds like a bitch...so being that i dont have access to a lift, i think ill deal with the rattle for a little longer
Formerly BlinkRA182
Old 12-23-2005, 07:59 PM
Linebckr49's Avatar
i dropped my tranny to install my LSD insert, and i just had a friend help me. didn't even need a transmission jack. the VR4 transmission is only about 80 lbs and can easily be dropped with two people. the FWD transmission is only about 60 lbs. its doesn't look that light, but it is.
93 3000GT base
