Go Back   Automotive Forums Car Chat > Renault > Renault 19
Old 12-21-2005, 09:42 AM
hobsonschoice hobsonschoice is offline
Blaupunkt radio cassette code
Hi gang,
Anyone got a code that works for the Blaupunkt RDs renault car cassette player?
Fed up looking at CODE.
Thanks
Old 12-28-2005, 07:52 AM
where to find blaupunkt code for RDS
First of all you need to pull out the steroe and take note of the serial numbers you see on the top or side.
If you are not sure how to remove the radio, you will need 2 small holes on either side of the unit. I used an old wire coathanger to do this. Bend 2 pieces of wire into a U shape. both should be about 5 inches long.
push th open end of the U wire into the two small holes in the left hand and the same again with the other wire in the right. By pushing the wires in you are forcing back the holding clips along the side of the unit making it free to pull out. You may have to jiggle around abit but i manged to pull it out after about 15 mins tops.
Once you have the serial numbers go to the link below and post the details including the car make etc.
Someone got back to me there within the hour with a successful code.
Happy days.
Dave
http://forum.eserviceinfo.com/archives/99999837.html
