Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-21-2005, 02:10 AM
jiloasis74 jiloasis74 is offline
'93 TBird wont start
I noticed my volt meter on the low side today. I stoped to put in gas and it did not start. All I got was clicking noice coming from the engine. Had someone give me a jump ran it for about 5min. then shut my car off and tried to restart it but, it was struggling to go on for a few seconds then the clicking noice started again as I was trying to start it.
I just bought a new batt. about 2mos ago and had my started replaced at the same time.
Whats up with my car??????Help?????
Old 12-21-2005, 09:35 AM
overl0rd overl0rd is offline
Re: '93 TBird wont start
Your alternator is most likely bad, check its output. You could have also gotten a dud battery, have it load tested.
Old 12-21-2005, 10:28 AM
Re: Re: '93 TBird wont start
Alternator? What is that? How much does on cost to replace. Whats a good price for a mechanic to charge to fix it IF I buy the part???? How many days does it take to fix it or is it pretty quick to fix???
Old 12-21-2005, 10:40 AM
TheDeal526 TheDeal526 is offline
I believe the price of an alternator varys, and depends on is you have a V6, or V8 and how many amps you car requires. I don't think you should be looking at much more the $150 if you buy an aftermarket and or refurbished alternator from an auto parts store. If you buy a brand new OEM alternator directly from Ford, the price may be alot higher than that.
No one should charge you anymore than $60 to install it.
Old 12-21-2005, 10:49 AM
Fuck me man, I love this forum you guys are spot fuckin on! Thx alot man. I guess this will be my cars litto christmas present.
How long does it take to fix???
Old 12-21-2005, 07:45 PM
jd-autotech jd-autotech is offline
voltage reg
you may need to just change the voltage regulator which is mounted to the case of the alternator but even if its is the alternator the book time is only1.0 hrs and dont over look the starter solenoid on the fender well near the battery u can use a insulated handled screw driver and touch the small s terminal to the larger pos. terminal and if starts the solenoid is ur trouble
Old 12-21-2005, 08:06 PM
Re: voltage reg
I got it fixed. My brother had me buy the alt. then he put it in for me. I thank god.
Happy Holidays to all.
