Old 12-21-2005, 01:17 AM
elmolus elmolus is offline
help identify gm engine
Hi to all! I'm new in this forum, I'm from Mexico (sorry for my english)
I need your help to identify a GM big block engine (I think could be 454 or 427 of the end of the 60's or 70's early) the numbers that I found on the engine are:
T0219IV, 18L141800
3918828T HIPERFPASS 3 TRUCK
CM3 COM2
I really apreciate your help, thank you!
Old 12-21-2005, 08:45 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: help identify gm engine
Could you specify where you found them. Also what color is the block?
1969 Olds Cutlass
1985 Olds Cutlass
2000 Ford Ranger
2001 Jeep Cherokee Sport
Old 01-10-2006, 05:46 PM
Re: Re: help identify gm engine
Hi, sorry for answer late, the engine in question belong to a friend of mine, and he told me he found the numbers and words in the following places of the block:
T0219IV : located on a ledge on the passenger side of the block deck at the front (we think that’s the engine assembly date); also there is the 18L141800 number
3918828T: located at the driver side of the block
HIPERFPASS 3 TRUCK: located at the rear face of the block inside the perimeter of the bellhousing mating surface; also near are the words CM3 and COM2
The engine block doesn’t have original color. The oil filter it´s a cartidge (old style) and the intake manifold it’s very tall! (no aluminium)
I hope this information help you, thank you a lot for your help!!
Old 01-16-2006, 08:43 PM
SpinnerCee's Avatar
SpinnerCee SpinnerCee is offline
Chilton educated guesses.....
T0219IV -- IV indicates a 1966-1968 Chevrolet Mark IV [big block] 396ci V8 with a Hydraulic camshaft installed in a Full-Size Chevrolet (Biscayne/BelAir/Caprice/Impala). Possibly made in Towanda [sp.] New York ["T"]. The "IV" is just coincidental to the Mark IV.
The specs for this engine are:
CR: 10.25:1
HP: 325@4800
TQ: 410@3200
Bore x Stroke: 4.094 x 3.760 in.
18L141800 -- "18" maybe ID as a '68 + vehicle Unit # [141800 - start at 100,001] -- "L" would be the vehicle assembly plant.
Old 01-17-2006, 04:38 PM
Talking Re: help identify gm engine
Thank's a lot for the information SpinnerCee!!
The engine runs GREAT in a 1989 Chevrolet 2500 pick up short bed...I'll send some pictures of the truck soon...thank you again for your help!
Old 01-21-2006, 11:13 AM
SpinnerCee's Avatar
HIPERFPASS 3 TRUCK cast into the block -- I think this has something to do with whether or not the block has four-bolt mains or not.
Old 01-21-2006, 04:45 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Respectfully, this does not sound quite right.
This may be a tall-deck truck block. Measure the width of the intake manifold to be sure. Compare it to a car-type BB engine. The truck blocks use a wider intake manifold.
Cars and light trucks used spin-on oil filters. The industrial- type big blocks used for medium-duty trucks often used cannister filters.
How tall is the intake? Trucks had lots of room for tall intake manifolds, but the cars used short intakes for hood clearance.
Finally, the word TRUCK cast into the block is a very good sign its a tall-deck engine.
These engines were usually heavy, low-revving, high-torque engines and are not a performance engine by any stretch of the imagination.
The heads, manifolds, pistons and valve train were all different from the car BB's and few ordinary BB performance parts fit. These engines can be built for performance (expensive!!) but they are a bear to fit in many chassis, due to their taller deck.
There are lots of them around. They were made in 366, 396 and 427 cid displacements. They often fool car enthusiasts because they look so similar to the desireable car BB engine.
However, I could be wrong here, its just a suggestion.
Old 09-22-2006, 09:59 AM
countrychevylover countrychevylover is offline
Hi everyone I am new here and just trying to find out a bit of information on a engine. My grandfather just bought a 1961 chevy convertable and the engine is not the right one.. Could someone help me find out what engine it is by the serial number or maybe a siet that could help me find out what car that engine came out of.. the serial number is 1109152-F0531C0
thank you for your help!!!
Old 09-22-2006, 08:02 PM
SpinnerCee's Avatar
My book only does 65-72 --- LOL
F 0531 C0 (is that C-O or C-zero?)
* Found a 1967 250ci I6 - 3spd. or OD w/ex. EM [smog pump] (Chevelle) -- "CO"
Specs:
Carb: 1 bbl.
HP: 155@4200
TQ: 235@1600
Bore x Stroke: 3.875" x 3.53"
CR: 8.5:1
Camshaft: Hyd.
.:: DigitalMIX by djSpinnerCee ::.
Old 09-25-2006, 05:18 PM
jveik jveik is offline
lol i bet its a 366, the one from before, them suckers are boat anchors except for the torque
Old 09-27-2006, 08:26 PM
MagicRat's Avatar
I would suggest you open a new thread and post this question. You may get a better response.
Old 03-21-2009, 08:34 PM
racer3 racer3 is offline
hi everyone im new i need help finding out what this engine is and what year the numbers on the passengers side deck are vk132800 the numbers on the back are the castings i do beleive they are 14016379 all i no is its a small block chevy...... im gona put it in my race car but want to no what it is and how much horse power...... thank everyone for the help
Old 03-23-2009, 07:59 AM
MrPbody MrPbody is offline
AF -Advisor
racer3,
Tha's an early 350 "truck" block. Can't say about the horsepower. What is the head casting (last three digit of the 7 or 8 digit number, found between the valve springs)?
If you're going to put it in a race car, it must be disassembled and checked carefully before using it. If it's all "stock", it won't be suitable for racing, unless the class you're in requires a "stock" low-performance engine. Even then, if "used", you're rolling the dice every time you hammer it.
Jim
Old 04-02-2009, 02:09 AM
big dwag big dwag is offline
Go to this site www.MORTECH.com You can find out what year the block and heads were made just write down your numbers from the back of the block & heads then match them off of the site.
Old 05-17-2009, 04:50 AM
www.pjstemplates.c www.pjstemplates.c is offline
www.pjstemplates.com
843-376-4826
