Go Back   Automotive Forums Car Chat > Chevrolet > Tracker
Old 12-20-2005, 07:11 PM
rickbb71 rickbb71 is offline
reprogramming keyless entry remotes for 2002 chevy blazer
I just bought a used keyless remote for my blazer. I need to reprogram it so I can use with my other remotes. Does anyone know how to do this. Thanks for your help
Rick
Old 12-22-2005, 09:45 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: reprogramming keyless entry remotes for 2002 chevy blazer
I dont think the Tracker and Blazers use the same remote? Might have been better off posting in the Blazer forum, but here are the 02 Blazer instructions:
All Extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Transmitter Programming:
1) With the driver door closed, hold down the power UNLOCK button on the door panel.
2) Turn the ignition switch to the ON position.
3) Turn the ignition switch to the OFF position.
4) Turn the ignition switch to the ON position.
5) Turn the ignition switch to the OFF position.
6) Release the power unlock button on the door panel. The remote control door lock receiver will respond by cycling the locks to indicate the receiver is in the programming mode.
7) Hold down the lock and unlock button on the transmitter for about 30 seconds. The locks will again cycle to confirm programming.
- REPEAT step 7 for each additional transmitter.
8) Turn the ignition to the ON position in order to exit the transmitter programming mode.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 12-25-2005, 06:31 PM
tom martin tom martin is offline
I have a 99 Suburban and have purchased a new remote and neet to program it. Do the above instructions apply to a 99???
