Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-20-2005, 02:26 PM
gunterstan69 gunterstan69 is offline
96 v6 contour surges
my contour is back to surging right after you start it in the cold weather once you get it woemed up its not bad but while it's cold it runs for a lil while while the rpms are up but then when they start to fall they fall below 500 and the car quits and answers please
thanks stan
Old 12-20-2005, 06:12 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
fuel filter.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-29-2005, 11:29 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 96 v6 contour surges
Your symptoms sound similar to ones a co-worker is experiencing on her 1995 Contour V-6. On hers, it starts okay, idles okay, but when she puts the engine under load (shifting into reverse or drive) the engine stumbles like it wants to die. Per suggestions on Contour.org, I checked the vacuum secondaries (aka Intake Manifold Runner Control, IMRC) to see if they close when the engine starts. They do not. She hasn't had me troubleshoot why they don't close, so I don't know this WILL fix her car, but it's at least something that could cause the symptoms. You may want to verify that your secondaries close when you start the engine. I think it was 1998 before the Contour got the electronic IMRC, so your '96 probably still has the vacuum operated secondaries.
Also, you might want to try adding a bottle of fuel injector cleaner to the fuel tank and drive for a hundred miles or so and see if that makes a difference. I've seen injector cleaner fix quite a few driveability issues.
-Rod
Old 12-30-2005, 02:57 PM
Re: Re: 96 v6 contour surges
-Rod
95s were the only year with vacuum operated secondaries. 96+ were all electronically controlled by the IMRC. If its not closing, theres probably carbon gunked up within the lower intake manifold. Theres a how-to on contour.org on how to clean the upper/lower intake manifold. There are some people on CEG that like to "pin" their secondaries open all the time. Its pointless without extra compensated timing in the lower RPM's, but regardless, ive ridden in cars with either pinned or gutted secondaries and none have studdered. Youll just lose low RPM torque.
I still stand by the fuel filter suggestion.
"The CEG Nazi"
www.contour.org
