Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 12-20-2005, 02:02 PM
3.3 cuin 3.3 cuin is offline
Fuel filter on 1994 Chrysler Concorde LSH
I know that this car has one in the fuel tank. But I was wondering if it has another one somewhere else?
Old 12-20-2005, 04:37 PM
97ConcordeLX 97ConcordeLX is offline
Look on pass. side in front of rear tire Thats where mine is on a 97
Old 12-21-2005, 04:57 PM
AWP9521 AWP9521 is offline
Re: Fuel filter on 1994 Chrysler Concorde LSH
It is located where 97ConcordeLX says, it will have those quick connect type fittings where you press in the 2 tabs and pull the lines off. Just an added note:
IMPORTANT! Always relieve the fuel pressure before changing or you will get a gasoline bath when disconnecting the tubing from the filter (Gas will still run out of the line so get a pan to contain it) the easiest way to relieve the pressure SAFELY, is to open the hood while the vehicle is running, open the Power Distribution Box on the drivers side and pull the FUEL PUMP relay, the engine will run for a few seconds then die, shut off the ignition then replace the relay, the line pressure will be relieved so you can change the filter.
