Old 12-20-2005, 09:14 AM
wraithdu wraithdu is offline
Cold weather idle
First - 2002 Cavalier, 2.2L OHV, 60k miles
New - plugs (single platinums I believe at 50k), wires, fuel filter, air filter
About 2 months ago, when the cold weather hit, I started having a strange problem at idle. The car normally idles at about 650-700 when warm, about 1000 while it's still cold. Well it started sticking at 1000 even after it warmed up. This never happened in warmer weather, only very cold. Sometimes hitting the throttle pretty good would return the idle to normal after it warmed up, but most of the time I have to turn the car off and restart it after it's warm. That always fixes the problem.
The idle does not surge, is not rough, and there's no loss of power or hesitation. There's no knocking, misfiring, stalling, etc. It just idles high. There hasn't been a significant change in fuel economy.
On a weird side note, my car, my g/f's car, and a buddy's car all got worse than usual gas mileage over the last two weeks...formulation change?
Last week I tried cleaning out the throttle body like the Haynes manual suggested with a little carb cleaner around the throttle plate, and sprayed some into the IAC port. I didn't take the IAC off cause the idle wasn't rough and it's crammed agianst the firewall pretty good, and I didn't feel like removing the throttle body. A GM guy suggested some Chevron Fuel System Cleaner. Tried it, no difference.
There's no check engine light either. Suggestions? ECM maybe?
Thanks.
Erik
Old 12-21-2005, 06:56 AM
Re: Cold weather idle
:bump
Little help here?
