Old 12-20-2005, 06:33 AM
etland etland is offline
Send a message via Yahoo to etland
Unhappy 1999 Trailblazer 4x4 Actuator Problem
Hello again guys. Need additional advice. 4X4 problems...Will not go into 4x4. lights just sit there and blink. Some times will make it into 4 HI but will blink after acceleration. Figured it was actuator...took to shop,,,,,tech estimates $700....sluggish actuator motor.
Questions:
Is this an electric motor?...LT has been recommending check vacumm so I am a bit confused to say the least. Nappa offers actuator in three models a 7 pin, a 6 pin, a 2 pin...whats the difference? Which one do I need?,....price range from 160-205.......any recommended sources? At least Nappa can find it....Oriellys, Adavance, and autozone cannot even loctate it in their books.
do you have any other suggestions that may be causing this actuator to have a sluggish motor?
by the way, WIfe is still pissed off about door.
lastly, if it is the actuator....where is it and what are the procedures to replace it? This is a fantastic site...you really should charge memebership or donation........if you do, perhaps i missed it.....where do you donate or what is the membership fee? Thanks again
Ernie
Old 12-31-2005, 11:23 AM
Re: 1999 Trailblazer 4x4 Actuator Problem
Another case where I have given more credit where credit is not due.......Thanks guys
Old 12-31-2005, 01:17 PM
pipelinerr pipelinerr is offline
Send a message via AIM to pipelinerr
Re: Re: 1999 Trailblazer 4x4 Actuator Problem
you can try discon bat for a couple of minutes this worked for me--pins are amount of electrical con. at elec motor on transfer case
Old 12-31-2005, 04:13 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
What transfer case 236 or 233 or other.
4 wheel Selecter buttons on dash?
Does it have a actuator solenoid/mt on front axel?
You need to get the codes if light is blinking at you.
Depending on what transfer case?
More info needed.
MT
MT
Old 12-31-2005, 04:30 PM
marly87 marly87 is offline
I hope it's not a serious problem. My '96 Blazer was doing the same thing. It also wouldn't go out of 4WD. I thought it was the transfer case. As it turns out, the button was stuck. My mechanic removed the switch from the dash and popped it out from the inside. Works fine now.
Old 01-01-2006, 01:16 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Your best bet is to simply pull the actuator and take with you up to the autoparts store to match it up. It's only 2 13mm bolts holding it on under the battery.
Old 01-01-2006, 07:18 PM
laxman21's Avatar
laxman21 laxman21 is offline
I picked on up at the u pull it yard for $10.
Here is how I changed mine:
http://www.automotiveforums.com/vbul...d.php?t=498812
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
