Old 12-19-2005, 11:07 PM
Laceybell Laceybell is offline
NO HEAT ~ 1998 Blazer
I have no heat anywhere - not on the floor or the defrosters or the vents. The blower works fine and you can switch to the different positions (defrost, floor, etc.) The hoses going into and out of the heater core are both HOT. The vehicle is equipped with the C86 climate control system. Regardless of where the temp is set, it stays the same ~ COOL. The temperature outside this morning was -7 F, but it still defrosted my windshield, so the temp is just a little bit warmer than the outside.
Old 12-20-2005, 12:44 AM
OverBoardProject OverBoardProject is offline
Banned
Re: NO HEAT ~ 1998 Blazer
Just because both heater hoses are hot doesn't mean that the heater core isn't 90% blocked.
Try a prestone flush kit, and reverse the heaters hoses while doing this. With a little bit of luck it'll flush any garbage out..
Lots of luck, and I hope that it's warmer there than it has been here the last month
Edit:
Welcome to Automotive Forum!
Old 12-21-2005, 06:46 PM
st8542's Avatar
st8542 st8542 is offline
Thumbs up
i have had the almost same probelm. i did the reverse heater core flush. i didn't use anything but water. out came little jelly balls. added more anti freeze and new radiator cap. now i have to turn the fan to low speed and sometimes the temp down as it's too hot...99 blazer lt
Old 12-22-2005, 08:11 AM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Need to check and see if blend air door motor is working.
Old 12-22-2005, 09:10 AM
billibong's Avatar
billibong billibong is offline
I agree wtih OBP. Probably a blocked heater core. Try the reverse flush. Usually has really good results.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
