Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-19-2005, 08:08 PM
ashencrumbs ashencrumbs is offline
Send a message via AIM to ashencrumbs Send a message via Yahoo to ashencrumbs
1988 Bonneville
Sirs,
I'm noticing that when my car is stitting with the engine running (no moving) the "check engine' light will come on. I don't think it's over heating. Also while driving I can hear a rumble cming from the right front wheel. (maybe the shocks?)
Any help would be great.
-A
Old 12-20-2005, 01:47 PM
jdq jdq is offline
Re: 1988 Bonneville
When the SES comes on does it idle surge or anything ,got to be more specific.
Rumbling could be wheel bearing,seems to be common.
Old 12-21-2005, 04:21 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1988 Bonneville
Get the car scanned, as that will tell you the cause of the check engine light. The rumble while driving is most likely a hub bearing.
Old 01-02-2006, 01:26 PM
found the problem
the check engine light was due to a problem with the EGR Flow. Put some Sea Foam in the car and it cleaned out the mechanism. The light went bye-byes.
Thanks.
-A
