Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 12-19-2005, 05:04 PM
rans6 rans6 is offline
Question transmission problem
I have a 1994 mazda 626 and the trans went out on it. I rebuild the transmission and it worked find for a day and a half, now when i put it in gear the car wouldn't move and the hold light start to blink , everything in the transmission is new except for the valve bady assbl and the turbine speed sensor, sometimes it would move for about 10 second and then it will go blank. have any one encounter this problem or have an idea how to check the turbine speed sensor and the valve boby or know how to pull the codes fro this transmission? please help.
Old 12-21-2005, 10:48 AM
kjbuente kjbuente is offline
Send a message via MSN to kjbuente Send a message via Yahoo to kjbuente
sounds like the valve body is damaged, rebuild it and see what happens. The rest of the tranny should still be fine. Is it like this in drive, or in all the gears?
If it ain't broken, Don't fix it!
Old 12-21-2005, 08:04 PM
Re: transmission problem
Thanks for the reply,
It does this in all the gears if get the rpm to 3000 it will move but woundn't change gears. Were could I get a new vale body or rebuilding kit for it?
Old 12-22-2005, 03:47 PM
mazdatech177 mazdatech177 is offline
just buy a trans assembly from a mazda dealer. you are just wasting your money doing it any other way. just so you know, even for warranty applications mazda doesnt let us rebuild the trans.
