Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 12-19-2005, 03:29 PM
Answerman40 Answerman40 is offline
tranny problem
I have a 1987 Jeep Wagoneer. The transmission will not shift out of 1st or 2nd gear (cant tell which) at normal operating speeds. If I punch the accelerator for an extended period, it will finally shift. It seems to "slide" into the next gear. Any idea what the problem could be? The Throttle Position Sensor tested ok. The TV linkage adjustment has no effect on it. The tranny fluid and filter are new and at correct levels.
Thanks.
Old 12-19-2005, 09:59 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: tranny problem
have someone check the line pressure of your transmission, especially the governor pressure; might be a sticking governor.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-20-2005, 12:10 PM
Re: tranny problem
Thanks.
After reading several other posts regarding this topic, I decided to go ahead and replace the throttle position sensor, even though it ohmed out ok. Low and behold the thing shifts perfectly now. Go figure.
