Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-19-2005, 12:18 PM
paribhakta paribhakta is offline
Send a message via Yahoo to paribhakta
Question Car Wont Start
My 1996 Contour wont start but the battery is okay because the radio is on. When I trun the key normally it would make a khrrrrr.... sound and the car would start but now it does not make any noise and it does not start. Any suggestions welcome.......
Old 12-19-2005, 12:34 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Sounds like the starter.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-19-2005, 01:22 PM
Re: Car Wont Start
how can that be fixed? also, there is some kind of soft ticking noise. I heard it when i got in the car. Its very very soft
Old 12-19-2005, 02:30 PM
Re: Re: Car Wont Start
Starter has to be replaced. I dont think there anyway to fix it, at least not cheaply. Ticking noise could be coming from the valvetrain. What motor do you have? That would give me a better idea.
"The CEG Nazi"
www.contour.org
Old 12-19-2005, 02:32 PM
Re: Re: Re: Car Wont Start
4 cylinder
Old 12-19-2005, 04:44 PM
Re: Re: Re: Re: Car Wont Start
4 cylinder
ok, i doubt its anything serious then. Could be just the valvetrain ticking or an exhaust leak.
"The CEG Nazi"
www.contour.org
Old 12-20-2005, 11:07 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Car Wont Start
the ticking is most likely the lifters, common problem when the zetec's get in the higher mileage. because the pre 98's have mechanical lifters
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 12-20-2005, 08:00 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
It wouldn't be lifter tick if the car isn't starting. I'd suspect it is a relay that is opening and closing rapidly due to low battery voltage. The radio draws A LOT less current than a starter. With a good battery, you should be able to start the car with the headlights on. Try it, do the lights basically go out while you're trying to start the car? If so, make sure the battery cable connections are clean and tight. If so, check the battery on a load tester. Or, if you have a multimeter, put it across the battery and see what voltage you see while someone cranks the engine. If it's dropping below 10.5 volts or so while attempting to start the engine, replace the battery.
-Rod
Old 12-20-2005, 10:00 PM
pre98zetec's Avatar
Re: Car Wont Start
he said he heard it when he got the car
-Josh-
Old 12-21-2005, 09:45 PM
shorod's Avatar
SHO No Mo
Actually, he typed that he heard it when he got IN the car.
-Rod
Old 12-21-2005, 10:07 PM
pre98zetec's Avatar
Re: Car Wont Start
bah my mistake..
need to get my eyes checked.
-Josh-
Old 12-21-2005, 10:35 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Car Wont Start
I agree with shorod, about the relay ticking from low voltage.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
