Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 12-19-2005, 11:48 AM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
reserve gas tank?
is there a reserve gas tank in the z32? when the low gas light comes on and when I fill it up it only fits around 12-13 gallons. one time I kept pumping the gas gun at hte gas station and it over flowed at 14 gallons. I have a 1991 twin turbo. thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 12-19-2005, 01:02 PM
medic300zx's Avatar
medic300zx medic300zx is offline
Re: reserve gas tank?
I do know the z31 has a reserve. You place $10.00 in tank when the reserve light is on an nothing. I usually have to place $25.00+ in the tank of the z31 to even start to register
Old 12-19-2005, 05:33 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
yea I was wondering the same thing becuase I had 1 bar showing on my gas tank (I have digital dash) and I put in 25 bucks and the damn thing overflowed...
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 12-19-2005, 07:44 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
i dont think there is a reserve gas tank on the Z32. i know that when the gas light comes on, you have 3-4 gallons left in the tank. personally, i have never seen the light come on in my Z and i have put 13 gallons in it before (i usually put 11-12 gallons in, i am paranoid and always fill up at the 1/4 mark).
ZedEx Crew Member #2
Old 12-19-2005, 07:57 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
medic... dude... could you maybe shrink your sig 'z' pic down a little... that thing is massive
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 12-19-2005, 08:27 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
yeah medic...shrink that thing down.
in a sense all cars have a reserve. it is the gas that is 'reserved' after the fuel gauge says Empty or your gas light comes on. that is your reserve. for most cars it is a few gallons. do Z's or any other cars have a reserve like motorcycles and such, usually no.
ZedEx Crew Member #4
Old 12-19-2005, 08:38 PM
This is kinda related, but what was wierd to me, is that my Z used to perform and feel the best when there was 3/4 to a full tank of gas in the car... I just assumed that it was becuase of the extra weight by the rear wheels... I was expecting a better performance or something when I was lower on gas becuase of the weight factor but yea... someone mind explaining htat to me???
Old 12-19-2005, 10:37 PM
Z Cars Fanatic
Re: Re: reserve gas tank?
in-tank fuel pump's are more efficient with more gas in the tank?...
the more gas in the tank, the more pressure can be built inside the fuel system.
my
Old 12-19-2005, 10:53 PM
actually, the fuel pressure regulator mantains a constant 43.4 psi, even in the fuel tank. but good guess k3.
Old 12-19-2005, 10:55 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Pfft! Just buy a 5 gallon fuel cell and you will always know when you are about to run out of fuel exactly!
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 12-19-2005, 11:04 PM
Z Cars Fanatic
umm....the regulator cannot make pressure appear. it stops pressure from going over a designated mark.
im telling you...fluid is heavier than air, therefore the more gas in the tank the more pressure at the bottom of the tank making it easier for the Pump to move the fuel through the line.
kinda like when you're ears pop the deeper you go in water. pressure is causing you're ears to pop...with enough pressure it will collapse your body. air cannot create this kind of pressure.
just thinking logically here...
Old 12-20-2005, 03:09 PM
Hodo Hodo is offline
The car performs better because of the added wieght over the rear tires. The weight split on the Z32 is a bit on the front heavy side, I think its close to 60/40 (not sure exactly). But with the fuel in the tank you can do the math, 17gal weighs about 181 pounds, thats water weight, so fuel you can venture to say would weigh about 170lb or so.
thats bit of wieght to have directly over the rear wheels.
I dont think it willo improve your 1/4mile time but it may improve you 60ft times and your track performance if you can deal with the added weight. But some cars actually are "faster" feeling with a fuel tank of gas, but in actuallity they are slower. I can say that a NA AT Z32 is faster in the 1/8th mile with less than a 1/4tank than with a full tank. But this my own experiance.
Finaly got pics of my car....... after I washed it of course.
Old 12-20-2005, 06:07 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
[FYI]I haven't weighed my Z personally but a Car and Driver article listed the TT as a 55/45 split.[/FYI]
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 12-21-2005, 02:20 PM
medic300zx's Avatar
Sorry Delerious - Was experimenting last night - Will try to fix But you got to admit the Z RULES and deserves a little show off now and then - lol
Old 12-21-2005, 02:22 PM
medic300zx's Avatar
Poosting again - How is this - no Z emblem
