Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 12-19-2005, 11:05 AM
sperk101 sperk101 is offline
Question high idle
2000, Mazda 626, 5 speed, 150,000 miles: Hi. The outside temps have dropped significantly in the last two weeks…just when I started having a high idle problem. When I start the car and go, it’s fine until have to put it in neutral. It normally idles at about 1000 rpm, but now it’s idles at 2500-3000. At times, the check engine light comes on, but always goes off as soon at I put it into gear. Once the car warms up, the problem goes away, and it seems to be fine on the highway too.
Should I let the car warm up some more before beginning to drive it?? Or is it something that I should have checked out ASAP? Anyone else have this problem in the cold temps?
Any input is appreciated!
Old 12-21-2005, 10:46 AM
kjbuente kjbuente is offline
Send a message via MSN to kjbuente Send a message via Yahoo to kjbuente
This sounds like a sensor going bad due to the temp. I would have it checked when you get a chance, I do not think that it needs to go right way. But do not push it off to long.
If it ain't broken, Don't fix it!
Old 12-21-2005, 01:15 PM
Re: high idle
Thanks for your input! This morning I let it warm up about 10 mins before driving...it's hard to listen to it revving and jumping all around, but once it finishes it's fit, the car runs fine.
Old 12-22-2005, 03:52 PM
mazdatech177 mazdatech177 is offline
Re: high idle
ive seen a couple of clutch pedal position switches go bad and cause a very high idle. though its hard to say without looking at the car with my own eyes.
Old 01-28-2006, 03:15 PM
unforgiving_86 unforgiving_86 is offline
Send a message via Yahoo to unforgiving_86
Question Re: high idle aslo
i have a 92 honda prelude 2.2 liter that dont idle high at all when u start it up just like normal u can evan driving it like normal but when u put in neutral after car has been drove it idles at 3,000 rpm's while rolling and but once u come to a complete stop it goes back to normal.. can sombody help me?
