Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-19-2005, 11:54 AM
tbasa69 tbasa69 is offline
88 ranger clutch
my clutch in my 1988 ford ranger 2.9l slips if i dont take it real easy but after the clutch is let out all the way it dosent slip at all wtf?
Old 12-19-2005, 12:50 PM
stuzman stuzman is offline
Re: 88 ranger clutch
Sounds like it's time for a clutch assembly.
Old 12-19-2005, 01:15 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
That is kinda confusing
Put it in your high gear and at about 35-40 mph and give her the gas.
If it does not slip your clutch is holding.
A clutch has to be let out all of the way for it to hold.
MT
MT
Old 12-19-2005, 06:11 PM
Re: Re: 88 ranger clutch
if i try to let it out normally it slips and wont hold. if i pump the clutch it sounds like theres air in the line would that cause the problem?
Old 12-19-2005, 09:50 PM
superiorite superiorite is offline
Send a message via Yahoo to superiorite
OK here is one thing I found I had a problem with on an old ranger I had, I live in the country so I have litle critters looking for new homes all the time, (ie Tailpipes top of motor and any hole they can find) Well anyway HTey chewed the rubber grommet out of the trany I think its an inspectioin cover of dome sort. But they Had made a nest in there when I sent to start the thing It spun all the crap they had put in there into the clutch giveing the same problem that your having. I dont know if this is your case but something mabey to consider if the Little Critters arround your place hate you as much as mine do LOL. Lets just say me and Mr 12 gauge took our vengence out and havent seen a critter arround in about 6 months. hehe
Old 12-19-2005, 09:59 PM
MT-2500's Avatar
AF - Advisor
Does it slip in high gear when you put the pedal to the metal?
MT
MT
Old 12-19-2005, 10:41 PM
MT
no, it only slips like when im on a hill stoped and try to start off or my girlfriend trys to drive it and rides out the clutch
Old 12-19-2005, 11:04 PM
MT-2500's Avatar
AF - Advisor
It is still holding then.
Go easy on slipping it on take off.
Put it in the lowest gear you have get the clutch pedal up fast.
You might give the girfriend some driving lessons or you you be putting a clutch in it for sure.
MT
MT
