Old 12-19-2005, 10:15 AM
Davescort97 Davescort97 is offline
Escort guy
Missing Coolant
My 97 SPI is a good car and it has never been overheated. I am losing about 12 ounces of coolant every 6 months. I am wondering where did it go? Just does it in the summer, not in the winter. Az, what do you think about this?
Old 12-19-2005, 11:18 AM
llerrad llerrad is offline
Hot weather, some fluid will evaporate in the surge tank to some degree if that's all your missing in that lenght of time would not worry over it. If you were dripping you would smell the coolant when you shut down you engine when hot or there would be crusting around hoses when there is a small leak.
Old 12-19-2005, 01:59 PM
Escort guy
Re: Missing Coolant
Thanks. I'll not worry about it. I thought there was a small leak in the headgasket. Not worth pulling it at this stage of time. Will wait until it blows steam out of the tailpipe, THEN, I'll worry about it.
Old 12-19-2005, 06:42 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
This may sound odd but here's how I check for leaks. Disconnect the cooling fan and just let it sit and idle. Don't let it get all the way in the red zone but let her get real hot. If you have a leak then it should show up then because of the pressure. Could be a hose, water pump, thermostat housing, radiator, etc. If you let 'er get real hot it should show op though. If it's cold out then you can cover the radiator with cardboard. I've had cracked coolant reservoirs too.
Nevada Tumbleweed
Old 12-19-2005, 11:55 PM
Escort guy
Re: Missing Coolant
Real good idea. I'll try it and let you know.
