Old 12-19-2005, 08:12 AM
pies pies is offline
auto start
just wondering if someone has the wiring colours to connect a compustart in a 2000 silverado , new style. got it for free with the extra module. lots of wires to connect and i don't want to make a mistake. thanks inadvance pies
Old 11-07-2006, 01:33 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: auto start
Did you get those wire diagrams by any chance? I am thinking of doing the same thing. I also have a 2000
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 11-07-2006, 02:32 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: auto start
If it is a elcheapo walmart special just drop it in the trash can and be done with it.
If you are going to do it get a good one.
And remember good installation is the best part.
You might find some wiring diagrams here.
http://www.bulldogsecurity.com/
MT
Old 11-07-2006, 02:59 PM
Re: auto start
Thank you very much
Old 11-08-2006, 01:18 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
Re: auto start
12volts red + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition white + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
Accessory orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue + brown plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Power Unlock white + brown plug at BCM
Lock Motor gray driver kick panel
Unlock Motor tan driver kick panel
Parking Lights+ brown + lt. blue plug at BCM
Parking Lights- white - lt. blue plug at BCM
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger - BCM
Notes: Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm lt. green - driver kick panel
Notes: Also found in the purple plug of the BCM.
Disarm No Unlock
Tachometer white ac ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector.
Wait to start dk. blue - instrument cluster
Notes: See DirectFax document 1090.
Brake Wire white + brake pedal switch
Parking Brake
Horn Trigger black - brown plug at BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
this should do the trick but make sure you have a multimeter and test all wires.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 11-09-2006, 07:52 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: auto start
MAKE SURE TO HAVE THE 2ND IGNITION HOOKED UP AND CORRECTLY OPERATING. If not, you'll be buying a new tranny for your truck.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 11-13-2006, 03:51 PM
pshadwick pshadwick is offline
Re: auto start
Second Starter
Third Ignition
Second Accessory
Keysense
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger - BCM
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
I'm having trouble finding this "red" connector in the ECM. None of them look red to me. Anybody got a picture of the ECM and can point out the wire?
I understand there is a tach signal at the cruise control (correct?) can I use that? If so do you know which wire?
Thanks...Paul
Old 11-14-2006, 07:20 PM
Re: auto start
Don't bother with that. Just take the 4 screws out that hold your gauge cluster in, pull it out and the one connector on the back you'll see a white wire. Use that for tach. It saves a lot of time versus out in the engine bay.
This is where I always grab it. I just did a full featured RS with keyless entry in a 2007 Silverado with the Duramax. From start to finish was 54 minutes.
Pioneer 4900mp
Orion C63 Coax rear
