Old 12-19-2005, 06:45 AM
werty2u werty2u is offline
Red face heater core
any info on how to replace thr heater core in a 1991 mazda 626 would be
ever so GRATE-FULL
Old 12-21-2005, 10:54 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: heater core
Hey werty-- try posting your question in the correct forum, and you'll get a bit more help. Go to this link:
http://www.automotiveforums.com/vbul...play.php?f=294
Generally, the heater core is an underdash or dash removal job, unless there's an access plate on the firewall. Good luck finding your answer.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-15-2006, 04:03 PM
onesimusmo onesimusmo is offline
Re: heater core
ever so GRATE-FULL
If the heater core is just clogged and not leaking, a simple fix that has worked for me consistently is to switch the inlet and outlet hoses on the firewall. The clogging is from constant one-way directional buildup of sediment and is often made worse or complete if you have added any radiator stopleak. By reversing the hoses you create a back-flush action that forces everything back into the general cooling system. If this works for you make sure to do a general cooling system flush afterwards so the same crud doesn't redeposit itself over time.
Old 02-16-2006, 07:38 AM
Re: heater core
Why not just run a hose in the reverse direction? No sense putting all that crap into your engine.....just my
