Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-19-2005, 05:59 AM
realjoe2000 realjoe2000 is offline
Denali/yukon wind noise
Anyone ever noticed a wind noise coming from there winshield in higher wind days? I have a 01 Denali XL that makes noise around the windshield when its a bit windy on the freeway. Thanks
Old 12-19-2005, 12:38 PM
YukonGMC YukonGMC is offline
Re: Denali/yukon wind noise
It's the two pieces of windshield trim. One on each side. If you open the doors up and look behind the black molding up near the windshield the trim has 4 screws. Take this piece off both sides and run 3M double stick tape the length that contacts the windshield and tape the trim piece to the windshield. After taping this piece to the windshield your noise problem should be gone. From the factory it was never fixed to the windshield.
Old 12-19-2005, 08:51 PM
WEF WEF is offline
Do you have a bug sheild? Aftermarket?
Old 12-20-2005, 05:18 AM
Re: Re: Denali/yukon wind noise
Thank you very much. I apreciate the advise. I 'm sure thats it. I was looking at that the other day but didnt know if there was anything I could do with that trim. Thanks again
Old 12-20-2005, 05:21 AM
Yes I do have a Stampede brand bug shield installed. But I need to figure this out before I have a Lund Visor installed. Thanks
Old 12-20-2005, 02:51 PM
WEF WEF is offline
As hard as this might be to believe, the bug shield is the problem. A factory GMC shield won't do it. Cross winds make the big difference so on a windy day, take the shield off and you will prove it. I'm sure you want to keep the shield so use the two sided tape trick mentioned by YukonGMC.
Old 12-20-2005, 09:24 PM
Bevl Hvn's Avatar
Bevl Hvn Bevl Hvn is offline
wind noise
the roof rack can cause noise as well.
I run YAKIMA racks and got HUGE noise until I put an air shield thing, kinda deflecter shield on that YAKIMA makes. That cut the noise way down. I am going to look at my windshield trim as well... that was a good tip.
Old 12-21-2005, 08:17 AM
Re: wind noise
It was the windshield trim for me. I run a GM bug/rock deflector.
