| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
TS-13 or X-22?
Hi!
I think, I need to clearcoat my TS-51 (it is look OK but I want to look it better) but I found so many problems with Tamiya TS-13 in this forum. I don't want to ruin my paint job and start over because in Russia prices for spraycans is very high =( Can I use acrylic X-22 Clear for coating? I know, I can. But there is any visual difference between TS-13 and X-22? Maybe TS-13 looks better? And X-22 is same as other Tamiya acrylic (I mean it can be scratched easily if airbrushed)? If I apply it with brush there is visible strokes? Even more - painting TS-51 was trickly (tried to paint wet as usual color like TS-8 and paint start to run down because part was round). Any advices how to proper paint metallic? |
yes, some differences: x22 is safe for uderlayer and decals, ts13 is simply better. an x22 clearcoated stuff is more plastic-like to me, a polished ts13.. well we know!
and... cans aren't cheap here: quetly over 7-8 eur, dammn great stuff
gio
Re: TS-13 or X-22?
Welcome!
You can definitely clear coat with X-22 (MPWR and (I think) Mickbench have shown their work with it - try searching for their threads). Let it dry thoroughly before polishing it out though and I wouldn't reccomend brushing it on! ![]() If you don't have and airbrush and don't have access to spray cans of Gunze Mr. Topcoat you can use the TS-13 - just build up several LIGHT coats at first!! First time I used it, I put it on too heavily and of course - disaster. Different colours will behave differently - it's always a good idea to test it out on scrap body before spraying your model. Then you will get a feel for how "wet" should a wet coat be before it starts running. HTH
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
As klutz_100 mentions Gunze B501 Mr. Topcote is as excellent a clear as I have ever used and it's safe over decals. I love it. I have to order it from Japan. That's what I use when I have to clear over any paint/decals that I suspect will be a problem. X22 is best airbrushed, not hand brushed, and needs a lot of drying time vs. the TS13 lacquer.
My Fotki Album |
Re: Re: TS-13 or X-22?
But what mean light coat for TS-13? How much cm away from part? I painted with TS-51 from 25 cm and it is OK for this paint but I painted TS-8 from 10-15 cm and it is almost not enough. =) Anyway, if I decide to coat with TS-13, should I wait about a month? Or if I paint with light coats first then it is not neccessary? How much time need between each clear light coat? Should I add a wet clear coat at end or not (if I don't planning to polish)? Thanks again. |
Re: Re: Re: TS-13 or X-22?
don't worry about a little OP: just polish it (7-8 days should be sufficent to me, someone here wait to cure more )so there's no way to explain better: try (and welcome here) more: search feature allow to introduce you to that matter (explained by masters, not average mods. like me) and also to other cool tips, like hot can painting & co...
gio
TS-13 and X22 each take alot of patience and care to apply. When done well, there is no visible difference between them.
This is X22 airbrushed over Tamiya acrylics: I've used both, and my F50 is the last model I will ever spray with TS-13. Sure, you can get a good shine from it, but I'm sick of having it ruin what's under it. Yes, I know, it can be used safely, lots of light coats to build it up, etc., but I have never ruined anything by spraying X22 on it. TS-13 is too unforgiving for me to choose to use it. If it were the only option, sure I'd probably suck it up and use it occasionally- but I'd much rather use X22. Here's a big advantage to using X22- since you've used Tamiya laquer as your base color, you can spray all the X22 you want on it- and if you're unhappy with the results, you can easily strip off the X22 without harming the laquer underneith. You definately can't do that with TS-13.
PHOTOBUCKET SUCKS |
Re: TS-13 or X-22?
gio
Re: TS-13 or X-22?
I love TS-13 but after a few nasty lessons now don't spray it directly from the can straight over decals and colour coats. Instead I decant it and apply 2 or 3 mist coats through the airbrush first. This creates a nice barrier after which I can go to town with the can. A couple more light coats and finish off with a wet one. I also sand down lightly between coats, to smooth out decal ridges and the like. I like to finish off with the can because I can use it outside where dust is less of a problem.
