Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 06-06-2002, 06:04 PM   #1
2000Xterra
Question My X is stalling...
Hey everyone, my 2000 Xterra is stalling every time I come to a stop. Sometimes if I put it in nuetral it won't die but then again sometimes it will. It's a very sporatic problem but one thing I do know is that it doesn't matter if the A/C or blower is on (ruling out one sensor) and that the car has to be at operating temperature (or above) to stall. The vehicle only has 30,000 miles which amazes me. I don't want to take it to the dealer just yet...
Anyone experienced a problem like this?
Thanks,
-chris
2000Xterra is offline   Reply With Quote
Old 06-06-2002, 06:34 PM   #2
OffroadX
Send a message via AIM to OffroadX
Can't tell if you have an auto or a manual transmission, but if it's a manual there's a TSB that sounds like it's the answer:
Service Bulletin Number: NTB00007
Bulletin Sequence Number: 995
Date of Bulletin: 2000/01
NHTSA Item Number: SB609976
Make: NISSAN TRUCK Model: XTERRA Year: 2000
Component: FUEL:FUEL INJECTION:IDLE SPEED CONTROL UNIT
Summary: SOME VEHICLES MAY EXHIBIT AN IDLE FLUCTUATION WHEN COASTING TO A STOP WITH THE CLUTCH DEPRESSED AND THE TRANSMISSION IN GEAR.
Hit your service dept. with that TSB number when you take it in.
Brent
OffroadX is offline   Reply With Quote
Old 06-07-2002, 09:38 AM   #3
2000Xterra
Hmmm
Geez Brent, are you the only X mastermind on this forum?
Does this TSB include automatic tranny X's? I checked the codes in the ECU and I am gettind a code 34 which I believe is the Knock Sensor. Could this Idle Control Unit be causing confusion to the ECU producing the code 34? For I hear absolutely NO knocking and the engine purrs pretty smoothly. (when running :-( )
-chris
p.s. -- thanks for your help!
Old 06-07-2002, 11:34 AM   #4
Schludwiller
XTerra Guy
Schludwiller's Avatar
Re: Hmmm
Yes. The rest of us all are quite stupid.
Xterra4x4.com and the Xterra Offroad Webring
Schludwiller is offline   Reply With Quote
Old 06-07-2002, 12:03 PM   #5
OffroadX
It's all smoke and mirrors. I'm not an expert, but I did stay at a Holiday Inn last night... :toothless:
Brent
Old 06-07-2002, 01:09 PM   #6
2000Xterra
Correction...
I didn't mean to offend anyone in my last statement, I was just hoping to get a few more responses and to credit Brent at the same time.
-Chris
Old 06-07-2002, 03:46 PM   #7
Schludwiller
XTerra Guy
Re: Correction...
-Chris
No problem. I was joking. We're all quite familiar with most of us around here. Nobody answered because we were all waiting for Brent to run to his service manual and get you the answer.
Old 06-07-2002, 04:51 PM   #8
2000Xterra
OK, cool. I don't want anyone hating the "X newbie"...
-Chris
Brent -- Does that TSB that you posted apply to automatic's?
Old 06-07-2002, 05:09 PM   #9
rrdstarr
rrdstarr's Avatar
Wink Re: Re: Correction...
Yeah, what he said!
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
rrdstarr is offline   Reply With Quote
Old 06-07-2002, 09:02 PM   #10
ChuckH
ChuckH's Avatar
Usually an idle fluctuation and stalling like described is an indication of an Idle Stabilizer Valve or Control unit problem, so I would say Brent's probably correct. Should be easy for the dealer to diagnose and fix.
ChuckH
ChuckH is offline   Reply With Quote
Old 06-10-2002, 02:12 AM   #11
OffroadX
All I know about the TSB is what it says. Appears to be manual tranny only.
Brent
Old 06-10-2002, 10:44 AM   #12
2000Xterra
thanks!
Thanks everyone, for allowing me to appear to know what I'm talking about when I called the stealership.
-Chris
Old 06-19-2002, 09:34 AM   #13
2000Xterra
Conclusion
Well, after having to bring it in twice, they finally figured out that it was the MAS. I also own a Dodge Stealth and know that those puppies run about $563 bones. Thank goodness we had about a thousand miles left on the warrenty so everything was free including the loaner truck they lent us. All is well now and figured I'd let ya all know.
Thanks again for all the input.
-Chris
Old 06-26-2002, 12:32 PM   #14
esoX
Sorry for my ignorance but what is an "MAS"? I need to know because my 2000 X automatic has started doing this same thing intermittantly. I think it may have to do with humidity, it seems like more humid days are when the problem shows. What is happening is after the X is warmed up and I stop at a light, the idle starts fluctuating wildly from 100 to 1500 rpm and eventually stalling. But as I said it is intermittant and when I had in the dealer last it never acted up and they did nothing, so it would help if I could tell them exactly what to look for.
Thanks for any help.
esoX is offline   Reply With Quote
Old 06-26-2002, 02:18 PM   #15
2000Xterra
MAS
Well, the MAS is the Mass Airflow Sensor. I'm not exactly sure the way Nissan likes to label it but if I recall in their explanation they quoted the "mass air sensor". Eithor way, this sensor controls the A/F (air to fuel) mixture ratio during acceleration and at idle. With other vehicles I've owned, the TPS or the Throttle Position Sensor controlled the idle so it threw me way off. Anyways, the MAS was calibrating the A/F too rich which was mainly noticed at idle -- resulting in engine stalls. My problem was very sporadic and sounds like your having the exact same symptoms I had. I've noticed a substantial increase in gas milage too.
If you wish, I have the receipt at home and can take a look at it to give you some part numbers. (if they're listed)
Hope this helps,
-Chris
2005 stalls and stalls and stalls... MN Ding Dong Focus | C Max 3 06-27-2011 08:52 PM
Another stalling problem (95 GS) Cmal Regal 3 12-12-2009 03:41 PM
2000 2.4 Stalling Issues SteveFord26 Cavalier Problem Diagnosis 7 09-11-2009 09:56 AM
1999 p71 cuts out temp light coms on, car dies/ stalls usedcopcardudenj Crown Victoria 3 08-09-2009 08:23 PM
Stall Stall Stall Nur_Stang Explorer | Explorer Sport Trac 1 05-07-2005 12:45 PM
