Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-18-2005, 11:08 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
safc2/boost question
Hey guys, my next mod is going to be a manual boost controller. My question is that with the safc2, is there a way to have like 2 different tuned setups? Like one for low boost and one for high boost, and be able to switch back and forth on the safc2? The reason behind this is so that I can get both boost settings dyno tuned, so I have good performance at the different levels so I don't have to make a trip to the dyno every time I want to raise/lower boost.
Thanks
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 12-18-2005, 11:17 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: safc2/boost question
I have a SAFC and there is no way to set two seperate tuning setups. Unless the version 2 is different... Why would you have to go to the dyno each time you adjust your boost? Don't you just tune it by using your SAFC and a EGT guage or a wideband?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-18-2005, 11:18 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Thanks
I don't know about through the safc2 but you can set up two boost settings if you get a dual stage boost controller. Which will let you have one setting for low boost applications and one for high applications.
1991 GSX 2.3 Stroker
Old 12-18-2005, 11:20 PM
Re: Re: safc2/boost question
Ya, I know about dual stage mbc's. I just thought it would be good to be tuned for both settings.
Old 12-18-2005, 11:24 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
I don't have an SAFC, but I've heard about what people do in your situation. I believe there's a "low throttle" and "high throttle" tune or something like that. I know the SAFC2's can have two separate tunes. They just use the "mid-throttle" or something like that for lost boost and the "high" throttle for high boost. This is all if i remember correctly. Or DSMLink could hae a different tune for every psi
now - 2000 civic
soon - 2002 is300
Old 12-18-2005, 11:34 PM
They do have a low throttle and high throttle setting. But how do you use that for low boost and high boost settings? I thought the low throttle was for when the your give it half throttle and less and the high throttle was for half throttle and more?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-19-2005, 08:23 AM
http://www.prostreetonline.com/buy/apexi_super_afc_ii/
There, they say it has two memory modes. Which SAFC are you using? If for whatever reasno you can't utilize this, then just tune for the higher boost level. Rich > Lean
now - 2000 civic
soon - 2002 is300
Old 12-19-2005, 11:49 AM
Great, thanks alot crunchy!
Old 12-19-2005, 04:34 PM
Re: Re: Re: safc2/boost question
no problem, send me a log when u can, maybe I can help get you to a safe tune. For me , safety > power, but it's my daily
now - 2000 civic
soon - 2002 is300
Old 12-27-2005, 01:35 AM
kjewer1 kjewer1 is offline
AF - Advisor
I wouldnt bother changing AFR for two different boost levels, but I would change timing. So the AFC doesn't really help much here, except that in richening up the mixture you also lower timing
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
