Old 06-06-2002, 04:22 PM
al4a13 al4a13 is offline
Question resistor box? what?
I just want to know what is the resistor box
I know that it's required to convert the dual point injector to multi.
But how does it hook up?
If i'm using everything from an LS (intake manifold, Ecu, etc...), will I still need this "resistor box"?
Please help if you know
Old 06-06-2002, 06:00 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
the injectors on our cars are peak and hold style, which require a resistor box to operate correctly. I havent really looked at mine, but you run the injector wires through that, then they go to the harness. The 92 and up civics have saturated injectors, which dont require a resistor box. I assume youre swapping an ls in your car? the only way you wont need the resistor box is if youre converting your car to be obd1, and thats a day at the park itself.
resistor box or wiring swap sportbikerider '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-09-2003 11:20 PM
Injector resistor Box problem blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-23-2003 05:50 PM
Resistor Box Question....(mpfi) Problem_Si '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-23-2003 10:16 AM
1990 Integra LS resistor box mrchris1979 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 05-19-2003 08:38 AM
resistor box civickiller '88 - '91 Civic | CRX | Wagon | Shuttlee 7 05-20-2002 06:27 PM
