Old 12-18-2005, 07:15 PM
ivanbliskavka ivanbliskavka is offline
Question Acts like alternator is bad, but battery light does not turn on while driving
Hello, very strange problem, Tried searching the forum, got nothing, please help.
Its a 94 accord 140k miles. A few days ago the car just shut off, no electrical working. After the key was removed hazards worked, but dimmed and died shortly. After the battery was charged, the car worked normal, about 1.5 days later, same situation.
The strange part is, when just the accessories are on, battery light is on, when you drive light is off, acting like it is not the alternator.
I am afraid that it is not a problem with the alternator because of the way the lights are working. Is there anything else to consider, before swapping the alt?
Old 12-20-2005, 06:56 PM
mpumas mpumas is offline
Re: Acts like alternator is bad, but battery light does not turn on while driving
Its probably the alternator not providing sufficient voltage to charge the battery. The voltage regulator is part of the alternator, so if you replace the alternator, you get everything. About 140K, the problem usually centers around the slip rings and brushes. When they wear out, things don't work right.
Old 12-21-2005, 10:18 AM
vicchang vicchang is offline
I strongly feel it's the alternator. Use a meter to measure the voltage at the battery with the engine running. It should be around 14V. If not, it's your alternator.
Most common alternator problem is the brush. The original brush should last 140 - 170 k miles. If you know how to take apart an alternator, you can check the length of the brush. You can just replace the 2 carbon brushes if it's worn. Cost around $5- $10.
If it's not the brush, suspect the regulator. You can replace it alone also.
Old 12-24-2005, 04:05 PM
Thanks
We opted to just get a new alternator. Will see result after it is installed in a few days. I was just worried that the problem was something else.
Thanks for the help.
Old 12-24-2005, 06:43 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Re: Thanks
Good choice, that should fix your problem, let us know...
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 12-27-2005, 08:56 PM
blacknight's Avatar
blacknight blacknight is offline
More than likely it was the altenator. Probably replace the battery also just to be safe.
Many times, with a dead battery it's hard to tell if it's a problem with the altenator not charging the battery or the battery having a dead cell and not accepting a charge.
what's that red button on your steering wheel.......OOOHHH MMMYYY GODDDD :22yikes:
