Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-18-2005, 06:52 PM
dipset1 dipset1 is offline
Power Antenna
When I had my stock CD player in my 99 integra the antenna worked fine it would only stay up if the radio was on...awhile ago I got a JVC KDG-210 and installed it with an adapter harness and the antenna would just stay down even if the radio was on which I didnt mind...Now my antenna just stays up is there any way I can get it to just come up when I have the radio on??? if not which wire controls the antenna so i can just disconnect it??? I think its blue but im not sure
Old 12-18-2005, 07:51 PM
R.s.D R.s.D is offline
Re: Power Antenna
yes its the blue one. its called remote i think. i would personally install a switch somewhere in the line just incase the need for radio arises ( yeah im old school )
Old 12-18-2005, 10:49 PM
InstallTech's Avatar
InstallTech InstallTech is offline
Re: Power Antenna
On some models of radio, there are two blue wires(one with a white stripe, and just a plain blue one). The blue/white is strictly for amp turn on, while the blue is usually the power antenna lead. Other models only have a blue wire that stays hot whenever the unit is on. If the only wire that you have is just the blue wire, then you'll need to install a toggle switch to shut the power to the power antenna off when you're not using the radio funtion.
I reject your reality, and substitute it with my own.
