engine swaping
I have a 2000 mitsubishi eclipes with intake,headers,exhaust,and i took out the engine regulator but i was wondering i wanna change the motor and what would be the best motor to switch it with.
Re: engine swaping
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
Re: engine swaping
none.....keep the one you have.
and what "engine regulator" did you take out? |
Re: engine swaping
i'm confused, i'll write up a bit for the thread at the top though, just so this question is answered to the fullest though...
engine swaps readily avail.-- think i heard EVO8 motor, which is the new version of the 4g63, the old 1g and 2g eclipse version is not compatible other than that--- any engine is capable of working w/ enough fabrication and money, i could drop in a rb26tt tomorrow if i had upwards of 15k $ for the parts and another 5-12 for the install.... does not mean its feasible, the only swap avail. i put above... other than htat keep the motor you have and put your regulator back on,.... i imagine your regulator is there to regulate your engine, but i've never heard of it, can you clarify?
![]() Don't act like you don't love it.
503/2000 |
If you are talking about a governor.....there is none to take off. One of the great beauties of the 3G is that there is no engine regulator (governor). So....my bet is that you took something off that isnt good...probably infact a bad thing you took it off....put it back on...NOW, and strap a huge 70mm turbo on that mother.
puting in the evo8 motor is a waste of money i just swap the heaed its cheeper in the long run and you also will end up keeping it a 2.4ltr insted of making it a 2.0
Re: engine swaping
just thought i would post this....
this guy dynoed his COMPLETELY STOCK ENGINE(meaning stock internals) running 14-15psi at 326whp/340tq. http://www.club3g.com/forum/showthread.php?t=52866 |
Re: engine swaping
^^ yeah, i said the evo 8 swap is readily available... i didn't say it was a GREAT swap... every swap costs a considerable amount of money
503/2000 |
