Old 12-18-2005, 05:46 PM
Lanyi Lanyi is offline
Question 1986 Buick LeSabre
My 86' Buick LeSabre will not start. It will crank over and has spark. I believe its getting enough gas as the plug was wet that I pulled. I replaced the crank shaft position sensor with no luck. Checked the trouble codes on the ECM, showed no problems. Any ideas. as to where to go next? Thank you,
Old 12-18-2005, 08:12 PM
maxwedge maxwedge is offline
A990 racer
Re: 1986 Buick LeSabre
Check compression to start with.
Old 12-18-2005, 08:41 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Then check the fuel pressure at the rail. Should be 35-45 psi range.
Old 12-19-2005, 10:06 AM
stuzman stuzman is offline
The timing (timing chain jumped) would be another possibility.
Old 12-19-2005, 05:44 PM
auto trainy auto trainy is offline
Did an 86 have a cps?
Old 12-19-2005, 05:47 PM
TrueLyFE's Avatar
TrueLyFE TrueLyFE is offline
My '87 with at least 220k (electrical problems cause odo to go out with headlights on, so probably more) had a broken timing gear - it's made of plastic. Would crank and crank, spark and fuel were good, but wouldn't start.
Don't know an easy way to check this, since someone else checked it out for us. But if you take off your oil pan and there are pieces of plastic in that mesh filter thing, then that's pieces of your timing gear
'93 Dodge Caravan, 3.0L, A670 - It runs.
'85 Chevrolet Camaro Z28, 305 HO, T-5 - Transmission died! Parked for repairs.
'87 Buick LeSabre, 3.8L - RIP. Lots of blood, sweat, and tears.
